# What is Perplexity Pro?
> Perplexity Pro is our premium subscription plan, designed to enhance your search experience with advanced features and capabilities.
## What do I get with Pro?
Perplexity Pro offers a significant upgrade in power, access, and productivity for users who need more from their research and question-answering tools.​
## Key benefits of Pro
    10x as many citations per answer for greater reference depth and transparency.​
    Access to Perplexity Create files and apps for experimental features and enhanced tools.​
    Increased file and photo uploads—seamlessly add context to any query.
    Extended access to Perplexity Research for deeper explorations.​
    Enhanced image generation for visual research tasks.​
    Limited access to video generation tools.​
    One subscription includes all our latest and most powerful AI models, such as GPT-5.2, Claude Sonnet 4.6, and Gemini 3.1 Pro, [see full list of supported models](https://www.perplexity.ai/help-center/help-center/en/articles/10354919-what-advanced-ai-models-are-included-in-my-subscription.md).
    Exclusive Pro Perks, including early releases, enhanced support, and more.​
## Pro Searches
Pro subscribers get extended access to Pro Search. There's nothing to turn on: when you use **Search**, Perplexity applies Pro Search automatically for tasks like multi-step reasoning, detailed research, and complex projects, up to your plan's limit.
## Powerful AI models and search modes
**Selection of powerful AI models**
When you need detailed answers with extensive sources, choose from Sonar (in-house model), GPT-5.2, Claude Sonnet 4.6, or Gemini 3.1 Pro. These models deliver comprehensive responses with multiple references.
For complex analytical questions, choose from Sonnet 4.6 Thinking (or o3-Pro & Claude 4.5 Opus for Max users), and Grok 4. These models excel at breaking down complicated queries that require multiple search steps.
> **For Advanced AI model queries, access may be limited during weeks of especially heavy usage.**
> [!TIP]
> **If your projects demand even more flexibility and volume, [Perplexity Max](https://www.perplexity.ai/help-center/help-center/en/articles/11680686-perplexity-max.md) unlocks advanced access to all advanced models, enhanced video tools, priority support, and early access to our newest features.​**
> [card] Best mode
> For quick searches, this default mode intelligently selects the most appropriate model based on your query type. “Best” mode is available without quota limits.
> [card] Research mode
> This mode automatically selects the optimal combination of models for in-depth research on complex topics, generating comprehensive reports without manual model selection.
> [card] Create files and apps
> Tackles complex projects on your behalf. Create files and apps has access to the most advanced tools and can craft everything from reports and spreadsheets to dashboards and simple web applications.
If you'd like a detailed breakdown, [this](https://www.perplexity.ai/help-center/help-center/en/articles/10354919-what-advanced-ai-models-are-included-in-my-subscription.md) article explains the modes in Perplexity, including Search and Deep Research, and which language models are available in each. Learn when to use specific modes for different types of questions and how to select the right AI model for your needs.
## Switching between models
You can switch between search modes and models in an existing session via the search box.
## File and analysis
Effortlessly upload files—including PDFs, CSVs, audio, video and images—and explore their contents using cutting-edge AI models like GPT-5 and Claude Sonnet 4.6.
## Discord channel
Join the Pro Discord channel via the invite link in your Perplexity account menu. [Contact support](https://www.perplexity.ai/?support=true#settings/account) if the link has expired.
## Generate images and videos
You can generate images and videos made with the latest image/video generation models. Read more [here](https://www.perplexity.ai/help-center/help-center/en/articles/10354781-generating-images-with-perplexity.md).
## Pro support
As a Pro subscriber, you can access exclusive support channels:
    **Pro channel on Discord**: Connect with our team and other Pro users.
    **Contact Support**: Reach out directly via the Help menu on [perplexity.ai](https://www.perplexity.ai).
## Subscription management
> [!WARNING]
> Cancel your Pro subscription before deleting your account.
    For desktop users, **[cancel through your settings page](https://www.perplexity.ai/settings/account)**.
    For app subscribers, use your device's subscription management settings.
## Why is my Pro status not visible?
If your Pro status isn't showing up:
**1. Check for payment issues.**
**2. Make sure your billing information is correct.**
**3. Verify you're logged in with the correct email.**
**4. Clear your cache and cookies.**
**5. Try resetting the app.**
If none of these steps worked, please [contact support](https://www.perplexity.ai/?support=true#settings/account).
- [What is Enterprise Pro?](https://www.perplexity.ai/help-center/help-center/en/articles/10352973-what-is-enterprise-pro.md)
- [What is Perplexity?](https://www.perplexity.ai/help-center/help-center/en/articles/10352155-what-is-perplexity.md)
- [What is Education Pro?](https://www.perplexity.ai/help-center/help-center/en/articles/12590157-what-is-education-pro.md)
- [What is Pro Search?](https://www.perplexity.ai/help-center/help-center/en/articles/10352903-what-is-pro-search.md)
