# What is Enterprise Pro?
> Enterprise Pro is built for teams that need accurate answers, fast, with the security controls IT approves, plus access to Perplexity Computer.
Enterprise Pro is built for teams that need accurate answers, fast, with the security controls IT approves. It is part of Perplexity Enterprise, Perplexity's plan for organizations, and gives your team access to Perplexity Computer, the agent that completes multi-step work on your behalf. Each Enterprise Pro seat also includes Perplexity Ask, Projects, and connectors, managed by your administrators.
For the hardest problems, Enterprise Max adds the most advanced models and the highest usage limits. See [What is Enterprise Max?](https://www.perplexity.ai/help-center/help-center/en/articles/12310544-what-is-enterprise-max.md)
> [Learn more or sign up for Perplexity Enterprise](https://www.perplexity.ai/enterprise).
## Perplexity Computer with Enterprise Pro
Computer is available on the Enterprise Pro and Enterprise Max tiers. Instead of only answering a question, Computer takes action: it researches across the web and your connected apps, creates documents and presentations, and runs scheduled tasks in the background. See [Computer for Enterprise](https://www.perplexity.ai/help-center/help-center/en/articles/13901210-computer-for-enterprise.md) for setup and administrator controls.
Computer tasks use credits. Each Enterprise Pro seat includes a monthly credit allocation, and administrators can make more credits available through the organization's shared credit pool. Ask and standard searches do not use credits. See [How Credits Work for Enterprise organizations — Member Guide](https://www.perplexity.ai/help-center/help-center/en/articles/13901321-how-credits-work-for-enterprise-organizations-member-guide.md).
## Benefits
Enterprise Pro includes nearly all Pro features, plus:
    **Perplexity Computer**: Hand off research, document creation, and recurring tasks to an agent that works across your organization's tools. See [Computer for Enterprise](https://www.perplexity.ai/help-center/help-center/en/articles/13901210-computer-for-enterprise.md).
    **AI model flexibility**: Switch between the advanced AI models included with your tier to suit each task.\* See [What advanced AI models are included in my subscription?](https://www.perplexity.ai/help-center/help-center/en/articles/10354919-what-advanced-ai-models-are-included-in-my-subscription.md)
    **Projects and connectors**: Search your organization's knowledge through shared Projects and centrally governed File Connectors. See [Using File Connectors in Perplexity](https://www.perplexity.ai/help-center/help-center/en/articles/10672063-introduction-to-file-connectors-for-enterprise-organizations.md).
    **File uploads**: Upload files to fact-check their contents, summarize key takeaways, and find similar sources. See [Enterprise file limits](https://www.perplexity.ai/help-center/help-center/en/articles/12009761-enterprise-file-limits.md) for current limits.
    **User management**: Add, remove, and manage team members, and combine Enterprise Pro and Enterprise Max seats in one organization.
    **Single sign-on (SSO)**: Sign in through your organization's identity provider. See [SSO Integration: Getting Started](https://www.perplexity.ai/help-center/help-center/en/articles/11200832-sso-integration-getting-started.md).
    **Dedicated support**: Every Perplexity Enterprise organization receives dedicated support.
*\*Some models available in consumer plans are not available in Enterprise plans.*
## Security and privacy
Your data is secure.
    **Production data access**: Access to production data is controlled through internal tools that require authentication and access control.
    **Usage data**: Usage data is collected on an aggregated and/or anonymized level.
    **Data retention**: Files attached to sessions are deleted after seven days. Organizations with 50 or more seats, or with at least one Enterprise Max seat, can also set custom session retention periods. See [Data Retention for Enterprise](https://www.perplexity.ai/help-center/help-center/en/articles/11652701-data-retention-for-enterprise.md).
    **Compliance**: Perplexity is SOC 2 Type II certified. See the [Trust Center](https://trust.perplexity.ai/) for more information.
Read more about [how Perplexity Enterprise Pro keeps your data secure](https://www.perplexity.ai/hub/blog/how-perplexity-enterprise-pro-keeps-your-data-secure).
### Is my data used to train AI?
No. Your organization's data is never used to train or fine-tune Perplexity's models. Perplexity's data protection agreements with third-party AI model providers, such as OpenAI and Anthropic, also prevent training on Perplexity data.
## Perplexity Enterprise in Japan
If you are based in Japan and considering Perplexity Enterprise, contact Perplexity's partner [SoftBank](https://www.softbank.jp/biz/contact-us/demand/ai/perplexity-inquiry/).
## Related articles
    [Data retention and privacy for Enterprise organizations](https://www.perplexity.ai/help-center/help-center/en/articles/11187708-data-retention-and-privacy-for-enterprise-organizations-and-users.md)
## Need more help?
Reach out to your account team or [contact us via **Help > Contact
Support**](https://www.perplexity.ai/?support=true#settings/account). Visit the
[Trust Center](https://trust.perplexity.ai/) for security and compliance
documentation.
- [What is Enterprise Max?](https://www.perplexity.ai/help-center/help-center/en/articles/12310544-what-is-enterprise-max.md)
- [What is Education Pro?](https://www.perplexity.ai/help-center/help-center/en/articles/12590157-what-is-education-pro.md)
- [What is Pro Search?](https://www.perplexity.ai/help-center/help-center/en/articles/10352903-what-is-pro-search.md)
