# Technical capabilities of Sessions
> Learn about Technical capabilities of Sessions, including Do Sessions retain context for follow up questions.
## Do Sessions retain context for follow up questions?
Sessions are designed to maintain context in follow-up responses. However, if you switch topics frequently within a session, it might need a bit of guidance to stay on track.
## Can I ask questions “offline” to generate responses without sources?
To receive responses generated solely from the AI's internal knowledge (without external web browsing/sources):
**1. Start a new session.**
**2. Locate the globe icon.**
**3. Toggle the "Web" option to OFF.​**
*Note: This setting can only be changed at the beginning of a new session.*
## How do I search for a Session?
Go to your History page and use the search bar. You can search by keywords or the title.
## What happens to Sessions that are created when I am signed out?
When a user creates sessions while not signed into their Perplexity account, the author of the session is considered "anonymous," and therefore, the session is not saved long-term. These anonymous sessions will be visible for 14 days, after which they will disappear permanently without the possibility of recovery.
To ensure that a session is accessible long-term, please sign into your account. All sessions created while signed in will be automatically saved to your History.
**Tip: **As long as the session is not older than 14 days you should be able to find the session in your browser history. Once logged back in, save the session to a project to avoid it expiring after the 14 days.
## Can I switch my Focus selection on a Session?
It is not possible to switch Focus within a session. If you want to use Focus mode, enable it at the start of a new session.
## How do you I share a Session?
Yes, you can share a session. Click on the "Share" button at the top right corner of the session, and select "Sharable" Anyone with the link will be able to view your session. See below:
[![](https://mintcdn.com/perplexity-help-center/VSbT8XXdqBYCrHHo/help-center/assets/img/8e76f105ff_f96r4cgQi06FYTwwgeq5tqfuqUDM5jhJ8a5xQ6pF.gif?s=3dc407465f55dcad0e64c5675f32011d)](../../assets/img/8e76f105ff_f96r4cgQi06FYTwwgeq5tqfuqUDM5jhJ8a5xQ6pF.gif)
- [Features](https://www.perplexity.ai/help-center/en/collections/18799290-features.md)
- [What is a Session?](https://www.perplexity.ai/help-center/en/articles/10354769-what-is-a-thread.md)
- [Deep Research and Model Council in Computer](https://www.perplexity.ai/help-center/en/articles/2026102603-deep-research-and-model-council-in-computer.md)
- [Computer for Enterprise](https://www.perplexity.ai/help-center/en/articles/13901210-computer-for-enterprise.md)
