# Using File Connectors in Perplexity
> File Connectors let Enterprise Pro and Enterprise Max members search connected cloud storage, attach cloud files to a query, and import files into Projects.
## About File Connectors for Enterprise Organizations
File Connectors for Enterprise Pro are built to unlock your organization’s information, making file search smarter, faster, and secure.
You’re able to connect Perplexity’s AI search directly to files stored in leading cloud storage services so you can find answers, compare documents, and surface insights from your team’s files using plain language questions.
Content you import into a Project is copied at the moment you import it. Perplexity keeps that copy as it was, so importing the same file or folder again is how you bring in later changes from the source service. Standard Search works differently: it queries the connected service when you submit a query, so it always reads the current file.
<table>
  <thead>
    <tr>
      <th>Method</th>
      <th>What Perplexity can use</th>
      <th>Storage and updates</th>
    </tr>
  </thead>
  <tbody>
    <tr>
      <td>Standard Search</td>
      <td>Supported files the connected account is authorized to open</td>
      <td>Searches the source service when you submit a query. Files are not copied into a Perplexity file index.</td>
    </tr>
    <tr>
      <td>Query attachment</td>
      <td>A specific file you select for one query</td>
      <td>Adds a snapshot to the session. Attach the file again to use a newer version.</td>
    </tr>
    <tr>
      <td>Project Files import</td>
      <td>Files or folders you select for a Project</td>
      <td>Adds static copies to Project Files. Import the content again to use a newer version.</td>
    </tr>
  </tbody>
</table>
Importing again updates the copies at the same paths. Files you delete or rename in the source service stay in Project Files until you remove them there.
### Third-party apps supported
Currently, Enterprise Pro users can connect the following online storage services to Perplexity:
    Google Drive
    Microsoft OneDrive
    SharePoint
    Dropbox
    Box
These connectors enable Perplexity to search through your files and provide conversational, accessible, and verifiable answers based on your content.
### How File Connectors work
File Connectors operate at both the organization-wide and personal level. Administrators are able to enable or disable specific connected services at a company level from the [Connectors](https://www.perplexity.ai/account/org/connectors) screen in Organization settings.
Once a service is enabled by an admin, every user can connect their own accounts and control which folders and files Perplexity is allowed to access. [File limits](https://www.perplexity.ai/help-center/en/articles/12009761-enterprise-file-limits.md) apply at a user level.
Files synced to a personal repository can only be searched by the individual who synced them—your data stays private and protected. Please note that other users with access to shared sessions will be able to see responses that reference files used in these sessions. However, they will still require permissions on the appropriate connected apps to view the full file contents.
For a more collaborative approach, you can also sync files to shared [projects](https://www.perplexity.ai/help-center/en/articles/10352961-what-are-projects.md). Within a project, anyone who’s been granted access can search for those files, but seeing the actual contents still depends on having the right permissions set in your original cloud storage. Please note that [file limits](https://www.perplexity.ai/help-center/en/articles/12009761-enterprise-file-limits.md) also apply to projects.
### **What file types are supported?**
File Connectors currently support:
    Google Docs, Slides, and Sheets
    Microsoft Office files (DOCX, XLSX, PPTX, XLS)
    PDF files
    CSV files
    RTF files
    ODT files
    Markdown (MD) files
    JSON files
    Text (TXT) files
You can sync individual files, multiple files, or entire folders. When selecting a folder, all files within it will be synchronized. Note that adding entire Drives isn't currently supported.
Currently, File Connectors do not support images, audio or video files. However, you can upload these files from local storage to sessions.
### File limits
Please note that there are file and size limits when uploading files to projects or personal repositories through File Connectors. These limits vary depending on the type of account (Enterprise Pro or Max).
You can learn more about file limits in [this article](https://www.perplexity.ai/help-center/en/articles/12009761-enterprise-file-limits.md).
## Setting File Connectors up
### How to activate a File Connector
These steps must be followed by each user in an organization to activate File Connectors enabled by organization admins.
Open **Plugins** in the sidebar and find your cloud storage service on **Discover** or search for it by name.
Open each service's connector page and select **Connect**.
Authenticate your account for each service
Check for the **“Connected”** status after successful authentication
To select which files and folders Perplexity should use, click the three dots (⋮) next to the Connector and choose **“Upload”**
**Step 6**
Pick the specific files or folders you wish to sync and confirm your selection
File connectors can also appear inside a plugin. Connecting a connector anywhere connects it for your account everywhere. Your connection applies inside every plugin, as do your organization's connector settings if you belong to an organization. See [What are plugins?](https://www.perplexity.ai/help-center/en/articles/2026100701-what-are-plugins.md).
If you don’t see options to connect a File Connector, or if you experience an issue with permissions, your organization admin may have restricted a specific third-party app. Get in touch with us to get help.
### **Using File Connectors in Your Searches**
There are two main ways to leverage your connected files:
**As a source for search**: Enable files or folders stored in your connected third-party apps as sources when creating a new session.
**As file attachments**: Add specific files from your connected storage as attachments to your queries.
You can explicitly choose when to use files from your third-party storage services as sources for your queries.
![Project Files import menu showing Google Drive, OneDrive, SharePoint, Dropbox, and Box.](https://mintcdn.com/perplexity-help-center/On42tFquTayj-spz/help-center/assets/img/file-connectors-figure-3-v2.png?fit=max\&auto=format\&n=On42tFquTayj-spz\&q=85\&s=bd5b6091f43062f6d4b82d4de86d7848)
## Keeping your data secure
### How Perplexity keeps your data secure
The content and associated metadata of these files are securely synced to our platform, and we never use them to train our models. Every file you connect stays secure. Data is encrypted at rest and in transit and stored in AWS S3, and all your credentials are encrypted both at rest and in transit, following SOC 2 Type II security standards.
Additionally, your organization is always in control of what gets synced. Admins can restrict specific third-party apps from the [Connectors](https://www.perplexity.ai/account/org/connectors) screen in Organization settings.
### Other important considerations
    In order to use files from a connected app on your searches, you must select specific files or folders to sync with Perplexity
    Your searches will not query files or folders that you have not explicitly selected to use with Perplexity, even if you've successfully connected your online storage.
    Import the file or folder again to bring in a newer version
    When a file is deleted from the connected third-party app, or when access to it is removed, the file is immediately removed from Perplexity
    If you disconnect your third-party app account, all synchronized files will be removed from Perplexity
    Each user can only connect one account per third-party app with their Perplexity account
- [Perplexity Enterprise](https://www.perplexity.ai/help-center/en/collections/11312901-perplexity-enterprise.md)
- [Enterprise file limits](https://www.perplexity.ai/help-center/en/articles/12009761-enterprise-file-limits.md)
- [File App Connectors for Perplexity Pro subscribers](https://www.perplexity.ai/help-center/en/articles/11185364-file-app-connectors-for-perplexity-pro-subscribers.md)
- [Using the Box connector](https://www.perplexity.ai/help-center/en/articles/13130932-using-the-box-connector.md)
