# FAQ: File App Connectors for Pro subscribers
> Learn about FAQ: File App Connectors for Pro subscribers, including What information is accessible in Perplexity and How often are files synced.
## **What information is accessible in Perplexity?**
After logging in, you can select specific files that will be uploaded as attachments in Perplexity. The content and associated metadata of these files will be synced for search purposes.
File connectors can also appear inside a plugin. Connecting a connector anywhere connects it for your account everywhere. Your connection applies inside every plugin, as do your organization's connector settings if you belong to an organization. See [What are plugins?](https://www.perplexity.ai/help-center/help-center/en/articles/2026100701-what-are-plugins.md).
## **How often are files synced?**
On the Pro plan, file syncing won’t be available. If you have made changes to the original file you will have to re-upload it
## **How is my account security maintained?**
All your credentials are encrypted both at rest and in transit, following SOC 2 Type II security standards.
## **Where is my data stored?**
Your synced files are stored in AWS S3.
## **Will my data be used to train AI models?**
No. Files from your connected accounts (Drive, Dropbox) will never be used to train models.
## **Can I share answers based on my synced files?**
Yes, you can share answers directly with other users. However, they'll only be able to view source files in citations if they already have access to those files in the original storage service.
## **Can I use file connectors in Projects?**
At this time, file connectors can only be utilized directly in a session.
## **What file types are supported?**
Following formats are currently support:
    Google Docs, Slides, and Sheets
    PDF, DOCX, XLSX, CSV, PPTX
    MD, JSON, and TXT files
    Audio and Video file formats
## **Why can't I select certain files?**
This might happen because:
**1. The file exceeds our 40MB size limit**
**2. The file type isn't supported**
**3. Browser extensions may be blocking the file picker (try disabling extensions or using an Incognito window)**
## **Why can't I connect my cloud storage service?**
If you're trying to connect to organization-managed storage, verify that your organization has granted permission for external access. Enterprise workspace users may be restricted if the service has been disabled by a workspace administrator.
## **Who can access files?**
Files synced to your personal repository are only accessible by you. Files synced to a shared project can be searched by anyone with project access, but only those with proper permissions can view the file contents.
## **Do you integrate with WhatsApp?**
Our WhatsApp integration is currently in beta and not fully functional yet.
- [Troubleshooting for File App Connectors (Pro subscribers)](https://www.perplexity.ai/help-center/help-center/en/articles/11185430-troubleshooting-for-file-app-connectors-pro-subscribers.md)
- [File App Connectors for Perplexity Pro subscribers](https://www.perplexity.ai/help-center/help-center/en/articles/11185364-file-app-connectors-for-perplexity-pro-subscribers.md)
- [Billing FAQ for Pro Plan Subscribers](https://www.perplexity.ai/help-center/help-center/en/articles/10353002-billing-faq-for-pro-plan-subscribers.md)
