# Troubleshooting for File App Connectors (Pro subscribers)
> Learn about Troubleshooting for File App Connectors (Pro subscribers), including Google Drive issues, OAuth scope settings, and Drive SDK configuration.
File connectors can also appear inside a plugin. Connecting a connector anywhere connects it for your account everywhere. Your connection applies inside every plugin, as do your organization's connector settings if you belong to an organization. See [What are plugins?](https://www.perplexity.ai/help-center/en/articles/2026100701-what-are-plugins.md).
## **Google Drive issues**
Google-specific settings may block integration. Here's how to fix them:
### **OAuth scope settings**
If your organization can't set access to "Unrestricted," try these alternatives:
**1. Select "Restricted: Only trusted apps can access a service"**
[![](https://mintcdn.com/perplexity-help-center/Qv3d0vQE9qMlZrQx/help-center/assets/img/2b3275092b_image__281_29.png?fit=max\&auto=format\&n=Qv3d0vQE9qMlZrQx\&q=85\&s=cbff87640e7e9d06e149366f7e6e7862)](../../assets/img/2b3275092b_image__281_29.png)
2\. Enable "For apps that are not trusted, allow users to grant access to OAuth scopes that aren't classified as high-risk"
### **Drive SDK configuration**
Check your Google Workspace settings:
Go to **Google Workspace** > **Drive and Docs** > **Features and Applications** > **Drive SDK**
Make sure to select "Allow users to access Google Drive with the Drive SDK API"
[![](https://mintcdn.com/perplexity-help-center/VSbT8XXdqBYCrHHo/help-center/assets/img/9733b5bc98_image__282_29.png?fit=max\&auto=format\&n=VSbT8XXdqBYCrHHo\&q=85\&s=cb3336c0518dc29a665bfad391bc6755)](../../assets/img/9733b5bc98_image__282_29.png)
This setting is crucial as it allows Perplexity to work with your Google Drive files.
- [Connectors & Integrations](https://www.perplexity.ai/help-center/en/collections/18799295-connectors-integrations.md)
- [FAQ: File App Connectors for Pro subscribers](https://www.perplexity.ai/help-center/en/articles/11185411-faq-file-app-connectors-for-pro-subscribers.md)
- [File App Connectors for Perplexity Pro subscribers](https://www.perplexity.ai/help-center/en/articles/11185364-file-app-connectors-for-perplexity-pro-subscribers.md)
- [Troubleshooting connectors](https://www.perplexity.ai/help-center/en/articles/2026091802-troubleshooting-connectors.md)
