Skip to main content
Single Sign-On (SSO) Integration Troubleshooting
Daniela Gomez avatar
Written by Daniela Gomez
Updated over a month ago
Best Practices Guide for SSO Troubleshooting
SCIM and SSO Overview
  • SCIM (System for Cross-domain Identity Management) automates user provisioning and deprovisioning.
  • Perplexity does not currently support SCIM but provides tools via its SSO platform (WorkOS) to manage user access effectively.
  • Organizations can enforce domain-controlled logins through their Identity Provider (IdP), allowing them to manage user access on their side.
2. User Provisioning
  • How it works:
    • Users are provisioned "just-in-time" when they log in via SSO/IdP, not when added to the IdP.
    • By default, organization admins must invite users on the Perplexity side.
  • Customizable Options:
    • Engineering can enable:
      1. Automatic login for users with an email domain owned by the organization.
      2. Auto-capturing all users with the owned email domain into the organization's Perplexity account.
3. User Deprovisioning
  • Default Behavior:
    • Users are not automatically removed from Perplexity when deprovisioned from the IdP.
    • If SSO is enforced and the IdP rejects a login, the user cannot access their account but will still appear in the system until manually removed by an admin.
  • Best Practice:
    • Ensure admins regularly review and manually remove deprovisioned users to maintain accurate account records.
4. Key Troubleshooting Steps
  • Verify if SSO is configured to enforce domain-controlled logins via the IdP.
  • Confirm whether just-in-time provisioning is functioning by testing a new user login.
  • For issues with deprovisioning:
    • Check if the IdP is rejecting logins for deprovisioned users.
    • Manually remove accounts from Perplexity as needed.
5. When to Involve Engineering
  • If you need to enable automatic login or auto-capture features for your organization, contact support.
