# Local and Remote MCPs for Perplexity
> Model Context Protocol (MCP) servers let you connect your tools and apps to answer questions on Perplexity.
## What are MCPs and how do they work with Perplexity?
MCP stands for Model Context Protocol and is a novel protocol that can be used to securely connect external data sources, tools, and services to AI tools like Perplexity. Think of MCPs as "connectors" that allow you to access your everyday apps through the Perplexity interface. You can perform actions, search for information, edit files, and more using MCPs.\
​Local MCP is available in the Mac app.
## What are Local vs. Remote MCPs?
Local MCP servers allow you to interact with files, databases, applications, and services on your computer while sending the minimum viable amount of data to Perplexity. Local MCP is particularly valuable when working with sensitive data like personal financial information, health records, or proprietary business data. Remote MCP servers, instead, require remote authentication and server-side connectivity to data.\
Perplexity currently supports local MCPs on the MacOS platform via the [Mac App Store](https://apps.apple.com/ie/app/apple-store/id375380948).
## Setup and Configuration for **Local MCP on MacOS**
Here’s how to activate **local MCPs** for the Perplexity Mac app:
Open **Plugins** in the sidebar.
Before you can add MCP Connectors, you have to install the helper application PerplexityXPC so that Perplexity can securely connect to your local MCP servers.
3\. Once the Helper is installed, open **Plugins** in the sidebar and select **Add custom** to add your MCP connector.
4\. On the **“Add Connector”** page, add an MCP Connector to the **“Simple”** tab
a. Add any name for “Server Name”, for example `MCP for AppleScript`
b. Add the command that is used to run the MCP server
    This can usually be found in the README of the MCP server. Read the instructions carefully.
    Make sure you have any requirements for the MCP server installed, for example `brew install node` if you need `npx` . Ask Perplexity if you need any help installing requirements on your computer.
    Enter the command after installing requirements. For example, for [[https://github.com/joshrutkowski/applescript-mcp](https://github.com/joshrutkowski/applescript-mcp)](https://github.com/joshrutkowski/applescript-mcp) the command is `npx -y @peakmojo/applescript-mcp`
5\. Select **"Save"**, then open the connector under **Plugins → Installed** (or **Customize → Connectors** if you don't see Plugins yet) and wait for the MCP server to show **"Running"**. Make sure the MCP server is running.
[![](https://mintcdn.com/perplexity-help-center/VSbT8XXdqBYCrHHo/help-center/assets/img/6fed85b1b4_Screenshot_2025-06-28_at_23_32_20.png?fit=max\&auto=format\&n=VSbT8XXdqBYCrHHo\&q=85\&s=164d475195bf465f77b61013a29626e4)](../../assets/img/6fed85b1b4_Screenshot_2025-06-28_at_23_32_20.png)
6\. Go to the Perplexity homepage and toggle your MCP on underneath **“Sources”**
[![](https://mintcdn.com/perplexity-help-center/Qv3d0vQE9qMlZrQx/help-center/assets/img/3d13917322_Screenshot_2025-07-15_at_15_45_32.png?fit=max\&auto=format\&n=Qv3d0vQE9qMlZrQx\&q=85\&s=9785916781ad1fee3649f48edb9df1a0)](../../assets/img/3d13917322_Screenshot_2025-07-15_at_15_45_32.png)
7\. Test your MCP server: Ask a new command in Perplexity that references the MCP server like “check my mac calendar”. This should run one of the MCP server’s tools and prompt you for confirmation.
### Example Configuration
[Embedded youtube video](https://www.youtube.com/embed/lEEZgR6NnB8)
[Embedded youtube video](https://www.youtube.com/embed/ZI-QZXIzzkI)
## Examples of Useful MCPs on MacOS
Examples of useful MCPs can be found on GitHub and other open-source websites. Since servers run on your computer, **please carefully check open source solutions to evaluate their security, privacy, and usability.**
A few examples of useful local MCPs on MacOS:
    Apple Notes: Search and edit your Apple Notes. Install from [[https://github.com/RafalWilinski/mcp-apple-notes](https://github.com/RafalWilinski/mcp-apple-notes)](https://github.com/RafalWilinski/mcp-apple-notes).
    Apple MCP tools: Create reminders, calendar events, send emails, etc. Install at [[https://github.com/supermemoryai/apple-mcp](https://github.com/supermemoryai/apple-mcp)](https://github.com/supermemoryai/apple-mcp) .
    Filesystem Access: Access a subset of your local directories, read files, search files, and more. Download at [[https://github.com/modelcontextprotocol/servers/tree/main/src/filesystem#npx](https://github.com/modelcontextprotocol/servers/tree/main/src/filesystem#npx)](https://github.com/modelcontextprotocol/servers/tree/main/src/filesystem#npx).
    iTerm: Give Perplexity the ability to control iTerm 2 with natural language. Try it at [[https://github.com/ferrislucas/iterm-mcp](https://github.com/ferrislucas/iterm-mcp)](https://github.com/ferrislucas/iterm-mcp).
Note that local MCP servers are not officially recognized by Perplexity or Apple. Do your own research based on discussions, reviews, issues, and developer reputation to evaluate how trustworthy open-source software is.
## What are Remote MCPs?
Remote MCP servers are **cloud-based services (SaaS tools)** that run on the internet rather than on your local machine. Unlike local MCP servers that live on your computer, remote servers are accessible from anywhere with an internet connection.
For example, you can use remote MCP for creating new issues in **Linear** through conversations in Perplexity, allowing you to quickly log bugs or tasks without switching tools. For example:* “Open a ticket about a file attachment bug and assign it to Tom,” *Perplexity will invoke the* “Open a Linear ticket” *tool*, *populate the title as* “File attachment bug,” *and assign it to Tom, all within Perplexity*.*
To add a remote MCP connector, open **Plugins** in the sidebar and select **Add custom**. Remote HTTP/SSE MCP servers also work inside imported plugins.
A remote HTTP/SSE MCP connector can also appear inside a plugin. Connecting it anywhere connects it for your account everywhere, and your connection and your organization’s connector settings apply inside every plugin. [What are plugins?](https://www.perplexity.ai/help-center/help-center/en/articles/2026100701-what-are-plugins.md)
- [Adding Custom Remote Connectors](https://www.perplexity.ai/help-center/help-center/en/articles/13915507-adding-custom-remote-connectors.md)
- [Use Remote Access](https://www.perplexity.ai/help-center/help-center/en/articles/19800009-use-remote-access.md)
- [Desktop App](https://www.perplexity.ai/help-center/help-center/en/collections/19800000-perplexity-desktop-app.md)
