# Audit Logs
> Track supported activity in your Enterprise organization with Audit Logs, using webhook delivery or the read-only Audit API.
## Overview
Audit Logs are available to Enterprise organizations with 50 seats or more, or with at least one [Enterprise Max](https://www.perplexity.ai/help-center/help-center/en/articles/12310544-what-is-enterprise-max.md) seat. Administrators can use them to investigate activity and monitor administrative changes.
You can receive events through a webhook, retrieve stored events through the Audit API, or use both. The API does not require a webhook and does not change an existing webhook configuration.
### Choose how to access audit logs
| Method | Delivery | Content |
| Webhook | HTTP POST to your endpoint | Event details and content, where recorded |
| Audit API | Requests from your integration | Recorded event metadata and content, with credential redaction |
*Table 1: Webhook delivery and Audit API retrieval.*
For events available through both methods, the API returns the recorded event metadata, including query text, answer text, and file names where present. Query and answer text is limited to the first 500 characters in both methods. The `comet_agent_action` exception described in this article also applies.
The payloads are not completely identical: the API uses different top-level field names and redacts credentials in certain webhook-setting changes. See [Data privacy and security](#data-privacy-and-security) for the scope of that redaction.
The webhook is the faster delivery path. The API has no guaranteed freshness interval. Do not treat it as a guaranteed complete copy of the webhook stream.
Audit Logs do not capture every action. Neither method records seat-tier changes made through SCIM, which synchronizes membership with your identity provider, or through bulk tools. Member additions and removals made through CSV bulk operations are also excluded.
## Before you start
* Confirm that your organization meets the seat requirement above.
* Ask an administrator with organization settings access to enable logging.
* To manage API keys, use a role with both **View audit logs** and **Perplexity API access**. Built-in administrators have both permissions; custom roles can be granted both.
* Confirm that API key creation is enabled for your organization. If it is not enabled, contact your account team to request access.
* For webhook delivery, prepare an HTTPS endpoint and an authentication value.
See [Enterprise roles and permissions](https://www.perplexity.ai/help-center/help-center/en/articles/11187754-enterprise-roles-and-permissions.md) for organization settings and API permissions. Audit API keys are separate from regular Perplexity API keys and Analytics API keys.
## Data privacy and security
Both methods can contain personal information and recorded content, not just activity identifiers. Depending on the event, metadata can include query and answer text, file names, target member emails, organization-setting values, and Perplexity Computer task details.
For webhook authentication-token changes, the API replaces the recorded old and new token values with `[REDACTED]`. For webhook URL changes, it removes credentials and the URL path, query, and fragment while retaining the destination origin when possible; cleared values remain identifiable as cleared.
These redactions apply to API responses for those webhook settings, not to webhook delivery or stored events. They do not remove other recorded personal information or content from API metadata.
Restrict access to collected logs according to your organization's privacy policies. Keep webhook URLs, authentication values, and API keys confidential, and revoke keys you no longer need.
For Enterprise-wide data practices, see [Data retention and privacy for Enterprise organizations](https://www.perplexity.ai/help-center/help-center/en/articles/11187708-data-retention-and-privacy-for-enterprise-organizations-and-users.md). The [Trust Center](https://trust.perplexity.ai) provides security and compliance documentation, and the [Data Processing Addendum](https://www.perplexity.ai/hub/legal/dpa) sets out contractual data-processing terms when incorporated into your agreement.
The session and file deletion settings in [Data Retention for Enterprise](https://www.perplexity.ai/help-center/help-center/en/articles/11652701-data-retention-for-enterprise.md) do not define Audit API retention. Treat your organization's retention policy for exported logs separately from Perplexity's storage of audit events.
A retention period for Audit API events is not specified here. Collect events promptly and retain copies according to your organization's policy; ask your account team to confirm the applicable retention terms.
## Enable audit logs
1. Go to [**Organization Settings**](https://www.perplexity.ai/account/org/details).
2. Open **Data and privacy**.
3. Under **Audit Log Settings**, turn on **Enable Audit Logging**.
   [![Audit Log Settings with the Enable Audit Logging toggle off.](https://mintcdn.com/perplexity-help-center/VSbT8XXdqBYCrHHo/help-center/assets/img/4e223dea80_Enable_2BAudit_2BLogging.png?fit=max\&auto=format\&n=VSbT8XXdqBYCrHHo\&q=85\&s=d63b4606c88adfad0dbcec3af53850fb)](https://www.perplexity.ai/help-center/help-center/assets/img/4e223dea80_Enable_2BAudit_2BLogging.png)
   *Figure 1: The Enable Audit Logging control in Audit Log Settings.*
For API-only use, leave the webhook fields empty and continue to [Query audit logs with the API](#query-audit-logs-with-the-api). For webhook delivery, complete these steps:
1. Enter your HTTPS endpoint in **Webhook URL**.
   [![Audit Log Settings with logging enabled, a Webhook URL field, and an optional Authorization Header field.](https://mintcdn.com/perplexity-help-center/VSbT8XXdqBYCrHHo/help-center/assets/img/b01c823af0_Audit_2BLog_2BSettings.png?fit=max\&auto=format\&n=VSbT8XXdqBYCrHHo\&q=85\&s=42d2df5403254f2c0df98178bdb9d006)](https://www.perplexity.ai/help-center/help-center/assets/img/b01c823af0_Audit_2BLog_2BSettings.png)
   *Figure 2: Webhook URL and Authorization Header settings.*
2. Click **Save** beside **Webhook URL**.
3. If your endpoint requires authentication, enter the value in **Authorization Header**.
4. Click **Save** beside **Authorization Header**.
Unless you specify an authorization scheme, Perplexity sends the value you enter as a Bearer token. See [Webhook authentication](#webhook-authentication) for the two supported formats.
After a supported action, confirm that your receiving endpoint receives a webhook event and returns an HTTP `2xx` response.
## Query audit logs with the API
Use the read-only Audit API to retrieve stored events for investigations or ingestion into a security information and event management (SIEM) system. You control when your integration requests events; no inbound webhook endpoint is required.
### Create an Audit API key
1. Go to **Organization Settings > Enterprise APIs** and find the **Audit API** section.
2. Click **Create key**.
   [![Audit API section showing Audit API keys, an enabled Create key button, and a masked demo key.](https://mintcdn.com/perplexity-help-center/lN4-vTQP2Eg_aYeG/help-center/assets/img/11652747-audit-api-create-key.png?fit=max\&auto=format\&n=lN4-vTQP2Eg_aYeG\&q=85\&s=258b31810570e1ebb3c0f2c64c42777e)](https://www.perplexity.ai/help-center/help-center/assets/img/11652747-audit-api-create-key.png)
   *Figure 3: Audit API key controls in organization settings.*
3. Enter a **Key name**, such as `SIEM production`.
   [![Create Audit API key dialog with an empty Key name field and a disabled Create key button.](https://mintcdn.com/perplexity-help-center/lN4-vTQP2Eg_aYeG/help-center/assets/img/11652747-audit-api-create-key-dialog.png?fit=max\&auto=format\&n=lN4-vTQP2Eg_aYeG\&q=85\&s=8a820c81495d9f61b2d5fe61edf39317)](https://www.perplexity.ai/help-center/help-center/assets/img/11652747-audit-api-create-key-dialog.png)
   *Figure 4: Name an Audit API key before creating it.*
4. Click **Create key**.
5. When **API key created** appears, copy the secret.
6. Store the secret securely. It is shown only once.
If the section is missing, ask an administrator to check both required permissions. If **Create key** is unavailable, follow the message on the page: enable audit logging if it is off, or contact your account team if API key creation is not enabled for your organization.
> [!WARNING]
> Keys belong to your organization, not their creator. Removing the creator or changing their permissions does not revoke a key. Revoke keys you no longer need; revocation stops requests using that key immediately.
### Connect your integration
Use your Audit API key to authenticate your integration. Each key can read only its own organization's audit events and cannot call model APIs.
See [Audit API](https://docs.perplexity.ai/docs/admin/audit-api) for the endpoint, authentication examples, request parameters, response fields, pagination, rate limits, and errors. Use that developer reference when building or maintaining a collector. A request can use either `after_id` or `before_id`, but not both.
### Content and event coverage
API metadata uses the event-specific fields stored for API retrieval, which can differ from webhook metadata, including for `comet_agent_action` as described below. Values can include text, nested objects, names, and email addresses; the fields present depend on the event and what was recorded. Some events have no metadata.
The shared metadata does not make the API and webhook envelopes interchangeable, or guarantee that every action is captured. The [credential redaction](#data-privacy-and-security) applies only to the API; the text limits and recording gaps apply to both methods.
For `comet_agent_action`, API metadata contains only `action` when recorded. The `url` and `action_params` fields are sent only through webhooks and are not stored for API retrieval.
Each successful API read creates an `audit_events_accessed` event that is available through the API, not the webhook. Request that event type explicitly when reviewing access; it is excluded from the default API feed.
### Data availability
Available history begins when your organization enabled audit logging, with no backfill of earlier activity. Stored history does not extend earlier than July 16, 2026.
> [!WARNING]
> Turning audit logging off stops new recording and makes API requests return `404`. It does not revoke keys or immediately delete stored events. Unrevoked keys work again when logging is re-enabled; keys can still be revoked while logging is off.
### How to verify it worked
Use the request example in [Audit API](https://docs.perplexity.ai/docs/admin/audit-api) to confirm that your integration receives a successful response. An empty event list can mean no events match the selected window and event type; it does not by itself indicate an authentication failure.
## Webhook authentication
You can secure your webhook endpoint with a Bearer token or a complete authorization value. Configure the value your receiving endpoint expects.
### Bearer token
Provide a token without a prefix, such as `YOUR_WEBHOOK_TOKEN`. Perplexity prepends `Bearer` and sends `Authorization: Bearer YOUR_WEBHOOK_TOKEN`.
### Custom authorization header
Provide a complete authorization value that includes its scheme. For example, `Splunk YOUR_HEC_TOKEN` is sent as `Authorization: Splunk YOUR_HEC_TOKEN`.
## Webhook delivery
### Request format
Perplexity delivers audit logs to your webhook URL as HTTP `POST` requests. The request body uses `application/json`.
### Authentication header
If you configured an authentication value, Perplexity includes it in the `Authorization` header. See [Webhook authentication](#webhook-authentication) for Bearer and custom-scheme formats.
### Response handling
Your webhook endpoint should return an HTTP `2xx` response to acknowledge receipt within 1 second. Perplexity records delivery errors, including HTTP `4xx` and `5xx` responses, but does not automatically retry failed or timed-out deliveries. Monitor your receiving endpoint for failures and missing events.
To recover a missed delivery, query the API for events in the affected period. Recovery is limited to events that were successfully stored and are still available; the API cannot reconstruct events that were never recorded.
## Webhook audit log schema
Webhook events use the fields below. For the API's different top-level field names, see [Audit API](https://docs.perplexity.ai/docs/admin/audit-api); the metadata comparison is covered in [Query audit logs with the API](#query-audit-logs-with-the-api).
| Field | Type | Required | Description |
| `uuid` | String | Yes | Event identifier |
| `timestamp` | String | Yes | RFC 3339 timestamp |
| `event_type` | String | Yes | Event type |
| `user_email` | String | Yes | Acting member's email |
| `ip_address` | String | Yes | Client address or non-IP marker |
| `user_agent` | String | Yes | Client user agent |
| `session_id` | String or null | No | Related-event identifier |
| `user_id` | String or null | No | User identifier, when recorded |
| `metadata` | Object or null | No | Event-specific data |
*Table 2: Webhook payload fields.*
A required string field can be empty when a value is not recorded. Do not assume that every `ip_address` value is an IP address.
### Event types
The following tables describe documented webhook event types, not a guarantee that every action is recorded or every type is available through both methods. For events available through both methods, the API returns the recorded metadata subject to the redactions described above. The `comet_agent_action` exception described in this article also applies.
#### User activity events
| Event type | Description |
| `login` | Successful sign-in |
| `query` | Search query submitted |
| `answer_generated` | Answer returned |
| `file_upload` | File uploaded to a query or Project |
| `file_download` | File downloaded from a Project |
| `file_delete` | File deleted from a query or Project |
*Table 3: User activity events.*
Query events can include `metadata.attachments`, with `file_uuid` and `file_name` for each attached file. Both methods can return these nested fields when recorded.
#### Thread events
| `thread_forked` | Thread copied |
| `thread_exported` | Thread exported |
| `thread_shared` | Thread shared |
| `thread_deleted` | Thread deleted |
*Table 4: Thread events.*
#### Membership events
| `member_invited` | Member invited |
| `member_invite_rescinded` | Pending invitation rescinded |
| `member_removed` | Member removed |
| `member_role_changed` | Member's role changed |
*Table 5: Membership events.*
#### Organization events
| `organization_settings_update` | Organization setting changed |
*Table 6: Organization events.*
#### Role and group events
| `role_created` | Custom role created |
| `role_updated` | Role details or permissions updated |
| `role_deleted` | Custom role deleted |
| `role_users_changed` | Users added to or removed from a role |
| `role_groups_changed` | Groups added to or removed from a role |
| `group_created` | User group created |
| `group_deleted` | User group deleted |
| `group_members_changed` | Group membership changed |
*Table 7: Role and group events.*
For `role_users_changed` and `role_groups_changed`, metadata can include an `action` value of `added` or `removed`. Use this field to distinguish the direction of a membership change.
#### Comet agent events
| `comet_agent_action` | Automated Comet action |
*Table 8: Comet agent events.*
#### Connector events
| `connector_connected` | Third-party Connector connected |
| `connector_disconnected` | Third-party Connector disconnected |
*Table 9: Connector events.*
#### Computer events
| `computer_task_started` | Computer task started |
| `computer_agent_action` | Automated action during a task |
| `computer_task_completed` | Task completed successfully |
| `computer_task_error` | Task failed with an error |
*Table 10: Computer events.*
### Webhook payload example
This illustrative JSON payload represents a query event delivered to a generic webhook. It is not an Audit API response.
```json theme={null}
  "uuid": "6ba7b810-9dad-41d1-80b4-00c04fd430c8",
  "timestamp": "2026-10-28T09:05:31+00:00",
  "event_type": "query",
  "user_email": "member@example.com",
  "ip_address": "203.0.113.45",
  "user_agent": "ExampleClient/1.0",
  "session_id": "query_abc123",
  "metadata": {
    "query_str": "What are the best practices for API security?"
## Platform-specific formatting
### Slack webhooks
For a webhook URL beginning with `https://hooks.slack.com`, Perplexity uses Slack's Block Kit format. The `blocks` array contains sections for the event type, member and client details, and event metadata when present.
Event type labels use title case with underscores removed. Slack formatting truncates individual metadata values at 500 characters and the metadata section at 2,500 characters, with a truncation notice for long values.
### Splunk HTTP Event Collector
When the authorization value starts with `Splunk`, Perplexity wraps the payload in an `event` object for Splunk's HTTP Event Collector (HEC). This illustrative example shows the wrapper:
  "event": {
    "uuid": "a1b2c3d4-e5f6-4789-abcd-ef1234567890",
    "event_type": "login",
    "session_id": null,
    "metadata": {}
### Generic webhooks
For other webhook destinations, Perplexity sends the standard JSON payload without a platform-specific wrapper. See [Webhook payload example](#webhook-payload-example) for the format.
## Common webhook scenarios
### Track research sessions
Use `session_id` to correlate a query with its answer. These steps use webhook field names; API top-level field names differ even when the event metadata matches.
**1. Find the query event**
Read `query_str` in the event's metadata. Record its `session_id` to find related events.
**2. Match the answer event**
Find the `answer_generated` event with the same `session_id`. When recorded, `answer` contains up to the first 500 characters of the answer, alongside the `model` used.
### Monitor file access
Use file identifiers to correlate uploads and downloads. Both methods can include recorded file and Project details in event metadata.
**1. Find the file upload**
Read the upload event's `file_uuid`. Record the identifier for comparison with subsequent events.
**2. Match file downloads**
Find download events with the same `file_uuid`. Use the actor and timestamp fields to see who accessed the file and when.
### Audit configuration changes
For `organization_settings_update`, the setting `key` identifies what changed. Both methods can include `old_value` and `new_value`; the API redacts credentials in the webhook settings described in [Data privacy and security](#data-privacy-and-security).
Filter stored webhook data by `user_email` in your own analysis system to track which administrators made changes. The Audit API does not support a user-email filter.
## Best practices
### Implement your webhook endpoint
* **Respond promptly**: Acknowledge receipt within 1 second.
* **Process asynchronously**: Queue received events for processing.
* **Validate payloads**: Check structure and content before ingestion.
* **Secure the endpoint**: Use HTTPS and validate the configured authentication value.
* **Monitor failures**: Record receiving-end errors and investigate delivery gaps.
### Store and analyze collected logs
* **Set a retention policy**: Keep collected logs for the period your organization requires.
* **Index relevant fields**: Use event type, actor, timestamp, and session fields for analysis.
* **Correlate activity**: Use `session_id` to connect related events.
* **Monitor patterns**: Investigate unusual access or administrative changes.
* **Maintain backups**: Preserve copies according to your organization's security and privacy policies.
## Troubleshooting
| Symptom | Possible cause | Next step |
| No webhook events | Logging or endpoint configuration may be incomplete | Check that logging is enabled and an HTTPS endpoint is saved |
| Endpoint returns HTTP `4xx` or `5xx` | The receiving endpoint rejected the request or encountered an error | Inspect receiver logs and the configured authentication value |
| Events missing after a delivery failure | Failed deliveries are not automatically retried | Monitor receiving-end errors; do not rely on automatic replay |
| API key section is missing | Required permission is missing | Check both permissions |
| **Create key** is unavailable | Audit logging is off | Enable audit logging |
| **Create key** is unavailable | Organization's API key creation is not enabled | Contact your account team |
| API returns no matching events | Window or event filter excludes events | Check dates and `event_type` |
| API returns `429` | Keys share the organization rate limit | Honor `Retry-After` |
*Table 11: Troubleshooting.*
Check [Audit API](https://docs.perplexity.ai/docs/admin/audit-api) for response codes and collection guidance. When you contact support, include the exact error and the steps you already tried. Also include the API request time or the time of the affected webhook event or delivery failure, with its timezone. Omit keys, tokens, authentication values (including full authorization headers), and sensitive event content.
## Frequently asked questions
### Can I use Audit Logs with fewer than 50 seats?
Yes. An organization with fewer than 50 seats can access Audit Logs if at least one seat is on the Enterprise Max plan. See [What is Enterprise Max?](https://www.perplexity.ai/help-center/help-center/en/articles/12310544-what-is-enterprise-max.md) for eligibility.
### What if I enabled Audit Logs by mistake and see an unexpected charge?
Contact your account team or [**Help > Contact Support**](https://www.perplexity.ai/?support=true#settings/account) to review the charge and any refund eligibility. See [Refunds](https://www.perplexity.ai/help-center/help-center/en/articles/10354288-refunds.md); disabling Audit Logs is not a promise of a billing reversal.
## Related references
* [Audit API](https://docs.perplexity.ai/docs/admin/audit-api)
* [Enterprise roles and permissions](https://www.perplexity.ai/help-center/help-center/en/articles/11187754-enterprise-roles-and-permissions.md)
* [What is Enterprise Max?](https://www.perplexity.ai/help-center/help-center/en/articles/12310544-what-is-enterprise-max.md)
* [Data retention and privacy for Enterprise organizations](https://www.perplexity.ai/help-center/help-center/en/articles/11187708-data-retention-and-privacy-for-enterprise-organizations-and-users.md)
* [Data Retention for Enterprise](https://www.perplexity.ai/help-center/help-center/en/articles/11652701-data-retention-for-enterprise.md)
## Need more help?
Reach out to your account team or [contact us via **Help > Contact Support**](https://www.perplexity.ai/?support=true#settings/account). Visit the [**Trust Center**](https://trust.perplexity.ai) for security and compliance documentation.
- [Enterprise roles and permissions](https://www.perplexity.ai/help-center/help-center/en/articles/11187754-enterprise-roles-and-permissions.md)
- [Role-based access control for connectors](https://www.perplexity.ai/help-center/help-center/en/articles/2026100201-role-based-access-control-for-connectors.md)
- [Connecting Perplexity with Snowflake](https://www.perplexity.ai/help-center/help-center/en/articles/14017006-connecting-perplexity-with-snowflake.md)
- [Data retention and privacy for Enterprise organizations](https://www.perplexity.ai/help-center/help-center/en/articles/11187708-data-retention-and-privacy-for-enterprise-organizations-and-users.md)
