# Comet Shortcuts
> Shortcuts in Comet turn frequent workflows into reusable quick prompts that you can run from anywhere in the browser.
## Introducing Shortcuts: Your Fast Lane to Prompts in Comet
Meet **Shortcuts**, a new feature in Comet designed to further enable your productivity by turning your favorite and most-used workflows into quick prompts you can call up anywhere in Comet.
## What are Shortcuts?
Shortcuts in Comet are like *mini AI agents*—custom, reusable prompts that handle everything from simple tasks to complex workflows. Instead of typing out a big instruction (or multitasking between sites and tools), you can:
    Trigger pre-written commands in seconds
    Combine multiple steps into one easy prompt
    Point prompts at specific sources or data (use @ mentions, files, or tabs)
    Boost productivity by letting the AI handle repetitive stuff for you
[Embedded youtube video](https://www.youtube.com/embed/8Q3_UPKAe1Y)
**Example Shortcuts:**
    `/update-tabs`: “Close all tabs I haven’t used in the past day. Sort all remaining tabs by app.”
    `/fact-check` : “Examine the claims in the tab and check credible sources to fact check the claims. Put results in an easy-to-read tabular format.”
    `/order-lunch`: “Go to DoorDash and order my usual Wednesday lunch with a \$1 tip—no approvals needed.”
    `/demoprep tomorrow’s meetings`: “Prepare a personalized demo briefing for all relevant meetings tomorrow.”
    `/yesterdays-product-performance`: “Report key performance stats from your favorite analytics dashboard for yesterday.”
Start using shortcuts and let Comet’s AI handle your daily workflows. Just type `/`, choose your shortcut, add any extra info if needed, and watch shortcuts boost your productivity
## How do shortcuts work?
    **Trigger Anywhere:** Type `/` to see your shortcuts in the search bar or sidecar
[![](https://mintcdn.com/perplexity-help-center/VSbT8XXdqBYCrHHo/help-center/assets/img/8ee20ec436_Frame_2.jpg?fit=max\&auto=format\&n=VSbT8XXdqBYCrHHo\&q=85\&s=a4d91fe3c693a1b563fc10f575792e47)](../../assets/img/8ee20ec436_Frame_2.jpg)
    **No Auto-Execute:** Entering a shortcut won’t auto-run it. You can add extra details or context after the shortcut before submitting. When ready, click submit and the shortcut will expand into its full prompt.
    **Combine shortcuts:** Use multiple shortcuts together, building layered, complex workflows in a single command.
    **Smart Inputs:** As you type `/`, a selector with your available shortcuts pops up, so you can quickly find, edit, or use the prompt you need.
    **Configuration-Friendly:** Set up shortcuts with custom research modes, data sources, or fact-checking steps—tailor each prompt to your workflow.
    **Easy Management:** Find and edit all your shortcuts on your Settings screen.
    **Default + Custom:** You’ll have a basic set of shortcuts by default, with more available in our library (coming soon) and the option to create your own custom triggers.
## How to create and edit a shortcut:
Type `/` in the search bar or in the sidecar
Click **“Create a shortcut”**
The shortcuts modal will open up where you can **enter your instructions (prompt), select a Search Mode, Model, Source**
Name your Shortcut and **click Save**
<video autoPlay loop muted playsInline width="800" height="555" src="https://mintcdn.com/perplexity-help-center/Qv3d0vQE9qMlZrQx/help-center/assets/img/321516605b_CleanShot_2025-07-31_at_18_40_46__281_29.mp4?fit=max&auto=format&n=Qv3d0vQE9qMlZrQx&q=85&s=e77414a679b5a2cd5d09afccecf56670" />
**To edit:**
**1. Open your Settings bar and go to Shortcuts**
**2. Click on the shortcut you want to edit and the modal will open up**
**3. Make changes in the modal and click Save**
[![](https://mintcdn.com/perplexity-help-center/Qv3d0vQE9qMlZrQx/help-center/assets/img/3baa2e2ded_Frame_21.jpg?fit=max\&auto=format\&n=Qv3d0vQE9qMlZrQx\&q=85\&s=e31cea59cbef12a240168cfd10e37277)](../../assets/img/3baa2e2ded_Frame_21.jpg)
## How to delete a shortcut:
**2. Select the shortcut you would like to delete**
**3. In the modal, click the three dots at the top and click "Delete" to confirm.**
[![](https://mintcdn.com/perplexity-help-center/Qv3d0vQE9qMlZrQx/help-center/assets/img/40846c5ac0_CleanShot_2025-11-25_at_14_49_29.gif?s=9f6fbaf9e4d64980881ca67248a5bda6)](../../assets/img/40846c5ac0_CleanShot_2025-11-25_at_14_49_29.gif)
## Frequently Asked Questions
**Q: Will my shortcut execute as soon as I enter it?**
A: No—this is intentional! You can add more input after the shortcut and then submit.
**Q: Can I use shortcuts anywhere in Comet?**
A: Yes, whether you’re in the search bar, sidecar, or in a new tab, shortcuts work across all inputs. Enter your prompt where it makes sense for you.
**Q: Will shortcuts show up in the prompt title or chat?**
A: Nope, when you click submit, the shortcut “code” transforms into the full prompt behind the scenes, so your workspace stays readable.
**Q: Can I use more than one shortcut in a single prompt?**
A: Yes, mix and match to stack workflows. Each shortcut translates to its designated task.
**Q: How advanced can shortcuts be?**
A: Shortcuts can run simple text commands, trigger smart research, interact with human-in-the-loop steps, or pull from apps/files you specify.
**Q: Where do I manage my shortcuts?**
A: Head to your** Account Settings **screen to find, organize, and edit your shortcuts.
- [Comet](https://www.perplexity.ai/help-center/en/collections/18799298-comet.md)
- [Comet Query Shortcuts](https://www.perplexity.ai/help-center/comet/en/articles/11906981-comet-query-shortcuts.md)
- [Accessibility on Comet](https://www.perplexity.ai/help-center/comet/en/articles/11583833-accessibility-on-comet.md)
- [Personalizing Comet](https://www.perplexity.ai/help-center/comet/en/articles/11583910-personalizing-comet.md)
