# Connecting Perplexity with GitHub
> Unlock instant search and actionable insights from your GitHub repositories
The GitHub Connector lets you query and combine information from your GitHub repositories directly in Perplexity.
This Connector is available for Perplexity Pro and Perplexity Max users, and for members of Enterprise organizations (Enterprise Pro and Enterprise Max plans).
## Why use it?
    Instantly discover code and information across your repositories and organization documents, with no manual searching or context switching.
    Integrate GitHub data with other connected productivity apps and web sources.
    Streamline organization-wide information management using Perplexity’s enterprise features.
## Privacy and data security
The GitHub Connector requires the following permissions to function:
    GPG Keys: Full control of your GPG keys.
    Organizations and teams: Admin access
    Organization webhooks: Admin access
    Public SSH keys: Admin access
    Repository webhooks and services: Admin access
    Codespace: Manage codespaces
    Packages: Write packages to GitHub Packages. Delete private packages from GitHub Packages.
    Delete repositories: Ability to delete any adminable repository
    Gists: Read and write access
    Notifications: Read access
    Project: Manage project
    Audit Log: Read access to audit log.
    Repositories: Public and private
    Personal user data: Full access
    Workflow: Update GitHub Action Workflow files.
### Enterprise-grade data security
For Enterprise users, we offer enterprise-grade protections and compliance including SOC 2 Type II certification, end-to-end encryption, strict data privacy measures, and granular user access controls. Your repositories and other GitHub data, just like any other Enterprise data, are never used for AI training, and robust safeguards ensure confidentiality and regulatory compliance. You can learn more in our [Trust Center](https://trust.perplexity.ai/).
Connecting Perplexity to your GitHub account is done at a personal level. This means that no one else in your organization is able to query your GitHub repositories. However, if you query them on a shared session, anyone with access to the session will be able to see the responses.
To maintain control over how Perplexity interacts with GitHub, organization admins can enable or disable the connector for all organization users.
## How to activate it
To activate the GitHub Connector:
Open **[Plugins](https://www.perplexity.ai/computer/plugins)** in the sidebar. Find the GitHub connector on **Discover** or search for it by name, then open its page.
Select **Connect**.
You will then be prompted to log in to GitHub to grant some permissions to the connector. These will allow the connector to have visibility of your repositories and account data, and perform actions on your behalf in GitHub. Click **Authorize** to start using Perplexity with GitHub.
This connector can also appear inside a plugin. Connecting it anywhere connects it for your account everywhere, and your connection and your organization’s connector settings apply inside every plugin. See [What are plugins?](https://www.perplexity.ai/help-center/en/articles/2026100701-what-are-plugins.md)
If you can’t connect the GitHub Connector on your account, an admin may not have enabled it for your organization. You can request your organization admin to enable it for your organization as part of the authentication step.
If it’s enabled for your organization but you still experience issues, contact us.
## Trying it out
Once you have connected Perplexity to GitHub, try running some of these queries to leverage your inbox and calendar information and perform actions directly from Perplexity:
    What is the status of my PRs?
    Add a 'preview' label to my latest PR
If you use [Comet](https://www.perplexity.ai/enterprise/comet), you can also ask the Assistant to perform these actions.
- [Troubleshooting the GitHub connector](https://www.perplexity.ai/help-center/en/articles/2026091803-troubleshooting-the-github-connector.md)
- [Connectors & Integrations](https://www.perplexity.ai/help-center/en/collections/18799295-connectors-integrations.md)
- [Connecting Perplexity with Guidepoint](https://www.perplexity.ai/help-center/en/articles/14818160-connecting-perplexity-with-guidepoint.md)
- [Get started with Perplexity teammates](https://www.perplexity.ai/help-center/en/articles/2026102601-perplexity-teammates.md)
