# Installing Comet for Enterprise (macOS)
> Install and manage Comet for Enterprise at scale across macOS devices in your organization.
This guide is intended for organizations that need to install Comet at large scale. If you’re looking for the individual Comet installer, you’ll find it [here](https://www.perplexity.ai/enterprise/comet).This guide covers deploying the Comet browser across your organization using Mobile Device Management (MDM) solutions on macOS systems.## **Prerequisites**To install Comet for Enterprise using MDM you will need:<ul>
    An MDM solution (Jamf Pro, Intune, Kandji, Mosyle, Workspace ONE, etc.)
    Access to your organization's Comet settings at [perplexity.ai/account/org/comet](http://perplexity.ai/account/org/comet)
    Your organization token (available from the Comet Setup page)
</ul>## **Overview**Mac policies are deployed using **Configuration Profiles** (`.mobileconfig` files) through your MDM solution. These profiles use the `ai.perplexity.comet` payload type to configure Comet settings.## **Getting started**First, you’ll need to download the Comet installer and obtain your organization token from: [perplexity.ai/account/org/comet](http://perplexity.ai/account/org/comet).The Comet for Enterprise installer is currently available as a `.dmg` macOS disk image.## Mass-deploying CometFor mass deployment using tools like Jamf Pro:**Step 1**Upload the `.dmg` file to your MDM solution**Step 2**Prepare a script that mounts the DMG, copies the **Comet** app to `/Applications`, and unmounts the DMG**Step 3**This script can be part of your post-install tasks or included in the package**Step 4**Use post-install scripts to:<ul>
    Handle app copy
    Set permissions
    Make Comet the default browser if required
    Configure first run settings (via plist manipulation if needed)
</ul>### Jamf Pro deploymentJamf Pro allows you to deploy and manage custom application settings in two different ways.<ul>
    Using just the **plist content** (without the full mobileconfig wrapper), where Jamf handles wrapping it into a proper configuration profile.
    Using custom JSON schema to provide a UI-based approach to managing policies (unique to Jamf)
</ul>> [accordion] Using plists
> #### **Step 1: Create configuration profile**
> **Step 1**
> Go to **Computers** → **Configuration Profiles** → **New**
> **Step 2**
> Enter a display name (e.g., "Comet Policies")
> **Step 3**
> Select **Application & Custom Settings** → **External Applications**
> **Step 4**
> Select **Upload**
> #### **Step 2: Configure preference domain**
> **Step 1**
> **Preference Domain**: `ai.perplexity.comet`
> **Step 2**
> Paste the plist content from the examples below
> #### **Step 3: Scope and deploy**
> **Step 1**
> Go to the **Scope** tab
> **Step 2**
> Add target computers or groups
> **Step 3**
> Click **Save**
> Before configuring browser policies, you must first enroll devices into your organization. This associates each Comet installation with your enterprise account for centralized management.
> Get your organization token from [perplexity.ai/account/org/comet](http://perplexity.ai/account/org/comet) and deploy the following plist:
> <pre>\<?xml version="1.0" encoding="UTF-8"?>\
> \<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "[http://www.apple.com/DTDs/PropertyList-1.0.dtd](http://www.apple.com/DTDs/PropertyList-1.0.dtd)">\
> \<plist version="1.0">\
> &#x20; \<dict>\
> &#x20;   \<key>CloudManagementEnrollmentToken\</key>\
> &#x20;   \<string>YOUR-ORG-TOKEN-HERE\</string>\
> &#x20; \</dict>\
> \</plist></pre>
> Once devices are enrolled, you can deploy additional configuration profiles to enforce browser policies. See examples below.
> ## **Example: Block extensions**
> &#x20; \<dict>\
> &#x20;   \<key>ExtensionInstallBlocklist\</key>\
> &#x20;   \<array>\
> &#x20;     \<!-- Metamask -->\
> &#x20;     \<string>nkbihfbeogaeaoehlefnkodbefgpgknn\</string>\
> &#x20;   \</array>\
> &#x20; \</dict>\
> \</plist></pre>
> ## **Example: Block URLs**
> &#x20; \<dict>\
> &#x20;   \<key>URLBlocklist\</key>\
> &#x20;   \<array>\
> &#x20;     \<string>chatgpt.com\</string>\
> &#x20;     \<string>\*.competitor.com\</string>\
> &#x20;   \</array>\
> &#x20; \</dict>\
> \</plist></pre>
> ## **Example: Multiple policies**
> Combine multiple policies in a single plist:
> &#x20; \<dict>\
> &#x20;   \<array>\
> &#x20;   \</array>\
> &#x20;   \<array>\
> &#x20;   \</array>\
> &#x20; \</dict>\
> \</plist></pre>
\> [accordion] Using Jamf Custom Schema for a UI-based approach
\> ### **Step 1: Create configuration profile**
\> **Step 1**
\> Go to **Computers** → **Configuration Profiles** → **New**
\> **Step 2**
\> Enter a display name (e.g., "Comet Policies")
\> **Step 3**
\> Select **Application & Custom Settings** → **External Applications**
\> **Step 4**
\> Select **Add**
\> ### **Step 2: Configure preference domain**
\> **Step 1**
\> **Preference Domain**: `ai.perplexity.comet`
\> **Step 2**
\> Select **Add Schema**
\> **Step 3**
\> Paste JSON Schema to populate configurable properties from the examples below
\> ### **Step 3: Scope and deploy**
\> **Step 1**
\> Go to the **Scope** tab
\> **Step 2**
\> Add target computers or groups
\> **Step 3**
\> Click **Save**
\> **Example: Homepage and startup settings**
\> <pre>\\{\
\> &#x20; "title": "Perplexity Comet – Homepage and Startup",\
\> &#x20; "description": "Control homepage, startup behavior, and New Tab configuration.",\
\> &#x20; "properties": \\{\
\> &#x20;   "HomepageLocation": \\{\
\> &#x20;     "title": "Homepage Location",\
\> &#x20;     "description": "URL of the homepage that is loaded when the Home button is pressed.",\
\> &#x20;     "type": "string",\
\> &#x20;     "property\\_order": 10\
\> &#x20;   },\
\> &#x20;   "HomepageIsNewTabPage": \\{\
\> &#x20;     "title": "Homepage Is New Tab Page",\
\> &#x20;     "description": "If true, the homepage is the New Tab page instead of a custom URL.",\
\> &#x20;     "type": "boolean",\
\> &#x20;     "property\\_order": 20\
\> &#x20;   },\
\> &#x20;   "ShowHomeButton": \\{\
\> &#x20;     "title": "Show Home Button",\
\> &#x20;     "description": "Shows or hides the Home button in the toolbar.",\
\> &#x20;     "property\\_order": 30\
\> &#x20;   },\
\> &#x20;   "RestoreOnStartup": \\{\
\> &#x20;     "title": "Restore On Startup",\
\> &#x20;     "description": "Configures what pages are shown at startup.",\
\> &#x20;     "type": "integer",\
\> &#x20;     "enum": \\[0, 1, 4],\
\> &#x20;     "options": \\{\
\> &#x20;       "enum\\_titles": \\[\
\> &#x20;         "0 – Open the New Tab page",\
\> &#x20;         "1 – Restore the last session",\
\> &#x20;         "4 – Open a list of URLs"\
\> &#x20;       ]\
\> &#x20;     },\
\> &#x20;     "property\\_order": 40\
\> &#x20;   },\
\> &#x20;   "RestoreOnStartupURLs": \\{\
\> &#x20;     "title": "Restore On Startup URLs",\
\> &#x20;     "description": "List of URLs to open on startup when RestoreOnStartup is set to 4.",\
\> &#x20;     "type": "array",\
\> &#x20;     "items": \\{\
\> &#x20;       "type": "string"\
\> &#x20;     },\
\> &#x20;     "property\\_order": 50\
\> &#x20;   },\
\> &#x20;   "NewTabPageLocation": \\{\
\> &#x20;     "title": "New Tab Page Location",\
\> &#x20;     "description": "Custom URL to use for the New Tab page instead of the default.",\
\> &#x20;     "property\\_order": 60\
\> &#x20;   },\
\> &#x20;   "ManagedBookmarks": \\{\
\> &#x20;     "title": "Managed Bookmarks",\
\> &#x20;     "description": "JSON-like structure defining a set of mandatory bookmarks managed by policy.",\
\> &#x20;     },\
\> &#x20;     "property\\_order": 70\
\> &#x20;   },\
\> &#x20;   "BookmarkBarEnabled": \\{\
\> &#x20;     "title": "Bookmark Bar Enabled",\
\> &#x20;     "description": "Shows or hides the bookmarks bar by default.",\
\> &#x20;     "property\\_order": 80\
\> &#x20;   },\
\> &#x20;   "DefaultBrowserSettingEnabled": \\{\
\> &#x20;     "title": "Default Browser Setting Enabled",\
\> &#x20;     "description": "Controls whether the browser can be set as the system default.",\
\> &#x20;     "property\\_order": 90\
\> &#x20;   },\
\> &#x20;   "BlockExternalExtensions": \\{\
\> &#x20;     "title": "Block External Extensions",\
\> &#x20;     "description": "Blocks extensions installed outside the browser when set to true.",\
\> &#x20;     "property\\_order": 100\
\> &#x20;   }\
\> &#x20; },\
\> &#x20; "required": \\[]\
\> </pre>
\> **Example: Force install extensions - e.g., 1Password and Okta Verify**
\> <pre>\\{\
\> &#x20; "title": "Perplexity Comet – 1Password and Okta Extensions",\
\> &#x20; "description": "Toggle force-install for 1Password and Okta extensions in Comet.",\
\> &#x20;   "ForceInstall\\_1Password": \\{\
\> &#x20;     "title": "Force install 1Password",\
\> &#x20;     "description": "If enabled, Comet force-installs the 1Password browser extension.",\
\> &#x20;     "default": false,\
\> &#x20;   },\
\> &#x20;   "ForceInstall\\_OktaPlugin": \\{\
\> &#x20;     "title": "Force install Okta browser plugin",\
\> &#x20;     "description": "If enabled, Comet force-installs the Okta browser plugin defined below.",\
\> &#x20;   },\
\> &#x20;   "OktaPluginExtensionId": \\{\
\> &#x20;     "title": "Okta browser plugin extension ID",\
\> &#x20;     "description": "Chrome Web Store extension ID for your Okta browser plugin (for example, from the Web Store URL).",\
\> &#x20;     "default": "",\
\> &#x20;   },\
\> &#x20;   "ExtensionInstallForcelist": \\{\
\> &#x20;     "title": "Additional force-installed extensions (advanced)",\
\> &#x20;     "description": "Optional: extra entries in the form extension\\_id;\\<[https://clients2.google.com/service/update2/crx](https://clients2.google.com/service/update2/crx)>. Rows here are in addition to 1Password/Okta switches above.",\
\> &#x20;       "title": "Extension ID and update URL",\
\> &#x20;       "default": "extension\\_id;\\<[https://clients2.google.com/service/update2/crx](https://clients2.google.com/service/update2/crx)>"\
\> &#x20;     },\
\> &#x20;   },\
\> &#x20;   "\\_info": \\{\
\> &#x20;     "title": "Info",\
\> &#x20;     "description": "Jamf will write a prefs key named ExtensionInstallForcelist. Enable the switches above to add 1Password and/or Okta automatically; use the array only for extra extensions.",\
\> &#x20;       "inputAttributes": \\{\
\> &#x20;         "readonly": true\
\> &#x20;       }\
\> &#x20;     },\
\> &#x20;   }\
\> &#x20; },\
\> </pre>
### Generic MDM deploymentFor MDM solutions that require a complete `.mobileconfig` file, such as Kandji, Mosyle, Fleet, SimpleMDM, etc., use the full configuration profile format below.#### **Deployment steps:****Step 1**Copy the example template and customize for your needs**Step 2**Generate unique UUIDs for `PayloadUUID` fields (use `uuidgen` in Terminal)**Step 3**Save as a `.mobileconfig` file**Step 4**Upload to your MDM as a custom configuration profile**Step 5**Assign to target devices or groupsBefore configuring browser policies, you must first enroll devices into your organization. This associates each Comet installation with your enterprise account for centralized management.Deploy a configuration profile containing your `CloudManagementEnrollmentToken`. Get your organization token from [perplexity.ai/account/org/comet](http://perplexity.ai/account/org/comet).<pre>\<?xml version="1.0" encoding="UTF-8"?>\
&#x20; \<dict>\
&#x20;   \<key>PayloadContent\</key>\
&#x20;   \<array>\
&#x20;     \<dict>\
&#x20;       \<key>PayloadType\</key>\
&#x20;       \<string>ai.perplexity.comet\</string>\
&#x20;       \<key>PayloadIdentifier\</key>\
&#x20;       \<key>PayloadUUID\</key>\
&#x20;       \<string>A1B2C3D4-E5F6-7890-ABCD-EF1234567890\</string>\
&#x20;       \<key>PayloadVersion\</key>\
&#x20;       \<integer>1\</integer>\
&#x20;     \</dict>\
&#x20;   \</array>\
&#x20;   \<key>PayloadDisplayName\</key>\
&#x20;   \<string>Comet - Organization Enrollment\</string>\
&#x20;   \<string>ai.perplexity.comet.org-enrollment\</string>\
&#x20;   \<string>Configuration\</string>\
&#x20;   \<string>B2C3D4E5-F6A7-8901-BCDE-F23456789012\</string>\
&#x20; \</dict>\
\</plist>\
</pre>Once devices are enrolled, you can deploy additional configuration profiles to enforce browser policies. See examples below.#### **Example: Block extensions**<pre>\<?xml version="1.0" encoding="UTF-8"?>\
&#x20; \<dict>\
&#x20;   \<array>\
&#x20;     \<dict>\
&#x20;       \<string>Comet Extension Blocklist Policy\</string>\
&#x20;       \<string>12345678-1234-1234-1234-123456789012\</string>\
&#x20;       \<array>\
&#x20;       \</array>\
&#x20;     \</dict>\
&#x20;   \</array>\
&#x20;   \<string>Comet - Extension Blocklist\</string>\
&#x20;   \<string>ai.perplexity.comet.extension.blocklist\</string>\
&#x20;   \<string>87654321-4321-4321-4321-210987654321\</string>\
&#x20; \</dict>\
\</plist>\
</pre>#### **Example: Block URLs**<pre>\<?xml version="1.0" encoding="UTF-8"?>\
&#x20; \<dict>\
&#x20;   \<array>\
&#x20;     \<dict>\
&#x20;       \<string>Comet URL Blocklist Policy\</string>\
&#x20;       \<array>\
&#x20;       \</array>\
&#x20;     \</dict>\
&#x20;   \</array>\
&#x20;   \<string>Comet - URL Blocklist\</string>\
&#x20;   \<string>ai.perplexity.comet.url.blocklist\</string>\
&#x20; \</dict>\
\</plist>\
</pre>
- [Comet](https://www.perplexity.ai/help-center/en/collections/18799298-comet.md)
- [Installing Comet for Enterprise (Windows)](https://www.perplexity.ai/help-center/en/articles/12763153-installing-comet-for-enterprise-windows.md)
- [Comet for Enterprise](https://www.perplexity.ai/help-center/en/articles/12781449-comet-for-enterprise.md)
- [Installing Comet](https://www.perplexity.ai/help-center/comet/en/articles/11583748-installing-comet.md)
