# Tips for Getting Better Answers from Perplexity
> Get better answers, images, videos, and documents from Perplexity with simple tips to help you write prompts that work — no technical skills required.
**The golden rule: State your intent clearly and provide detail.** \
Tell Perplexity exactly what you want to do — create an image, generate a video, search for information, build a document. The more specific information you include in your prompt, the better the results you'll get. \
Think of it this way: a vague request gets a vague response, but a detailed prompt with clear intent delivers exactly what you need.
## Searching for answers
Perplexity searches the live web in real time, so you always get up-to-date information with clear sources. The key to great results? Be specific.\
## Tips for searching
    **Start with a clear question.** Instead of typing a single word like "inflation," try "What is the current inflation rate in the US?"
    **Add context.** The more background you give, the better. For example: "I'm a first-time homebuyer in the US — what federal programs are available to help me?"
    **Use keywords that matter.** Include key terms that help focus the response. For example: "best noise-cancelling headphones under \$200 for commuting."
    **Say how you want the answer.** You can ask for a summary, a table, bullet points, or a step-by-step guide — just include that in your prompt.
## Examples
    ✅ "Compare the pros and cons of hybrid vs. fully electric cars for city driving."
    ✅ "What are the latest CDC guidelines on vitamin D supplementation for adults?"
    ❌ "Cars" *(too vague — Perplexity won't know what you're looking for)*\
Deep Research
Need more than a quick answer? Research mode digs deeper — it searches multiple sources, reads through documents, and pieces together a comprehensive analysis for you. Think of it as having a research assistant that works in minutes, not days.\
## Tips for deep research prompts
    **Be clear about what you want to learn.** A focused question leads to a focused report. For example: "What are the key trends in remote work adoption across the United States since 2020?"
    **Ask follow-up questions.** Research mode works great in conversation. Start broad, then drill down: "Now focus on the impact on employee productivity."
    **Upload your own files.** You can attach PDFs, documents, or data and ask Perplexity to analyse them alongside web sources. For example: "Based on the attached financial report and latest market data, what's the outlook for this company?"
    **Combine sources.** Try prompts like: "Cross-reference my uploaded lecture notes with the latest studies on reinforcement learning and summarise the key takeaways."
## Examples
    ✅ "Research the environmental impact of fast fashion and suggest sustainable alternatives, including cost comparisons."
    ✅ "Summarise the main arguments for and against a four-day work week, with supporting data."
    ❌ "Tell me about fashion" *(too broad — narrow it down to get useful results)*\
Creating images
Perplexity can generate custom images right inside your conversation. Just describe what you'd like to see, and an image will be created for you automatically.\
## Tips for image prompts
    **Be as specific as possible.** Describe the subject, style, colours, mood, and setting. The more detail, the better the result.
    **Mention a style if you have one in mind.** You can ask for watercolour, photorealistic, minimalist, cartoon, vintage — whatever fits your vision.
    **Include context about how you'll use it.** For example: "Create a professional-looking banner image for a tech blog about AI."
    **Iterate and refine.** If the first result isn't quite right, tweak your prompt and try again. Small changes can make a big difference.
## Examples
    ✅ "Generate a watercolour illustration of a cosy coffee shop on a rainy New York street, warm lighting, autumn colours."
    ✅ "Create a clean, minimalist logo concept for a sustainable clothing brand called 'Evergreen.'"
    ❌ "Make me a picture" *(too vague — describe what you actually want to see)*
Creating videos
You can generate short videos directly from a prompt. This is great for social media content, product demos, or creative projects. You can even upload a photo to use as the starting frame.\
## Tips for video prompts
    **Describe the scene and action.** Think of it like writing a mini script — what's happening, where, and what's the mood?
    **Keep it focused.** Generated videos are short, so aim for one clear concept per video.
    **Attach a reference image.** If you have a photo you'd like to animate or build from, upload it with your prompt.
    **Think about the end goal.** If you're creating an ad or social post, mention that — it helps set the right tone and style.
## Examples
    ✅ "Generate a short video of a steaming cup of coffee on a wooden table with soft morning light, slow zoom in."
    ✅ "I want to sell my vintage desk lamp (photo attached). Generate a stylish video ad I can post on social media."
    ❌ "Make a video" *(needs more detail about what the video should show)*\
Creating documents, presentations, and spreadsheets
Perplexity can create complete files for you — documents, slide decks, spreadsheets, and even simple web apps. Everything is backed by research with built-in citations, so your work stays credible.\
## Tips for document creation prompts
    **State the file type you need.** Be explicit: "Create a Word document," "Build a slide deck," or "Make a spreadsheet."
    **Describe the structure and content.** For example: "Create a 10-slide presentation on our Q4 marketing strategy, with sections on budget, channels, and KPIs."
    **Refine with follow-ups.** After the first draft, use follow-up prompts to edit, add, or restructure. For example: "Add a conclusion slide" or "Make the executive summary shorter."
    **Export when ready.** Download your files as DOCX, PDF, PPTX, or XLSX — whatever you need.
## Examples
    ✅ "Create a professional PDF report on the current state of renewable energy in the United States, with charts and citations."
    ✅ "Build a spreadsheet comparing the top 5 project management tools by price, features, and user ratings."
    ❌ "Write something for me" *(be specific about what you need and in what format)*\
General prompting best practices
No matter what you're asking Perplexity to do, these principles will help you get better results every time:
    **State your intent clearly.** Start by saying exactly what you want: "Create an image," "Generate a video," "Search for," "Build a presentation." This tells Perplexity what action to take.
    **More information = better results.** The more detail you provide, the better your output will be. Include context, specifics, preferences, and constraints. A rich, detailed prompt produces a rich, detailed response.
    **Be specific, not vague.** The clearer your prompt, the better the output.
    **Give context.** Who are you? What's this for? A little background goes a long way.
    **One thing at a time.** Don't cram multiple unrelated requests into a single prompt.
    **Say what format you want.** Table, bullet points, report, slide deck — just ask.
    **Iterate.** Your first prompt doesn't have to be perfect. Refine and follow up.
    **Use plain language.** You don't need to speak like a machine. Write the way you'd explain it to a colleague.\
FAQs
**Do I need to be technical to use Perplexity?**
Not at all. Just type naturally, like you're asking a knowledgeable friend. Plain language works best.\
**What if my first result isn't great?**
That's totally normal. Try rephrasing your prompt with more detail, or ask a follow-up question to steer the response.\
**Can I combine features in one conversation?**
Absolutely. You can search for information, then ask Perplexity to turn it into a document or presentation — all in the same session.\
**Is there a limit to how much I can generate?**
Usage depends on your subscription plan. Pro and Max subscribers get higher limits for search, image generation, video creation, and document building.\
**Where can I use these features?**
All features are available on web, iOS, and Android. Some advanced features require a Pro or Max subscription.
- [Getting Started](https://www.perplexity.ai/help-center/help-center/en/collections/12702161-getting-started.md)
- [Getting started with Perplexity](https://www.perplexity.ai/help-center/help-center/en/articles/10354975-getting-started-with-perplexity.md)
- [Practical Tips for Using Perplexity](https://www.perplexity.ai/help-center/help-center/en/articles/10352971-practical-tips-for-using-perplexity.md)
- [What is the difference between a prompt and a search?](https://www.perplexity.ai/help-center/help-center/en/articles/10354937-what-is-the-difference-between-a-prompt-and-a-search.md)
