# SharePoint and OneDrive Connectors: File Upload Security
> How and when Perplexity connects to SharePoint and OneDrive via API or indexed modes, without training models on your data
Perplexity's **[Microsoft 365 connector (SharePoint and OneDrive)](https://www.perplexity.ai/help-center/en/articles/12569435-microsoft-365-connector-sharepoint-and-onedrive.md)** enables Enterprise Pro and Enterprise Max users to search their organization's SharePoint sites and OneDrive files directly through AI-powered natural language queries.
We have recently introduced a hybrid search architecture that addresses both data security concerns and scalability limitations through two distinct search modes: **High-Precision Search** (indexing-based) and **Standard Search** (API-based).
## Search Architecture: Two-Tier Approach
### Standard Search (API-Based)
#### **How It Works:**
    Queries SharePoint/OneDrive directly via Microsoft's Search API at query time
    No file copies stored in Perplexity infrastructure, aside from results found from queries (can be mitigated by data retention policy settings)
    Searches across the user's entire SharePoint/OneDrive drive without file count limitations
    Available to all Enterprise Pro/Max users immediately upon connector activation
#### **Security Model:**
    **Zero Data Retention:** Files are not copied or stored in Perplexity systems, aside from results found from queries (can be mitigated by data retention policy settings)
    **Real-time Permissions:** Respects SharePoint's/OneDrive's native access controls dynamically
    **Minimal Data Copying:** Only citation snippets included in answers are retained
    **No Model Training:** Synced files are never used to train AI models
    **Immediate Access Revocation:** When SharePoint/OneDrive permissions change, access is immediately reflected in Perplexity
**Use Case:** Organizations requiring maximum data privacy and minimal data footprint, especially for searching across millions of files at enterprise scale.
### High-Precision Search (Indexing-Based)
    Users select specific files/folders to sync for local indexing in Perplexity
    Files are downloaded, parsed, and stored in dedicated AWS S3 buckets with vector embeddings in Vespa
    Enables deeper semantic analysis and more comprehensive answers
    **File Limits:** 10,000 files and 5 GB per Project, on every plan
    **Total User Limits:** 15,000 files (Enterprise Pro), 50,000 files (Enterprise Max)
    **Dedicated Storage:** Each organization's files stored in isolated AWS S3 "folders" with unique namespaces in Vespa vector storage
    **Encryption:** AES-256 encryption at rest, TLS encryption in transit
    **Role-Based Access Control (RBAC):** Minimum privilege access enforced across all systems
    **Updates:** imported copies stay as they were at import time. Import the content again to bring in changes.
**Use Case:** Teams requiring maximum answer accuracy for frequently accessed documents, project-specific file collections, or collaborative projects with curated content.
## Backend Architecture & Data Flow
### Connection & Authentication
    **Admin Enablement:** Organization admins enable the SharePoint/OneDrive connector in **[Organization settings → Connectors](https://www.perplexity.ai/help-center/en/articles/2026100201-role-based-access-control-for-connectors.md)**
    **User Authentication:** Users authenticate via OAuth 2.0 through Microsoft Entra (Azure AD)
    **Site Selection:** Users select specific SharePoint sites to connect
    **Admin Consent:** Microsoft admins may need to grant organization-wide consent for Perplexity app in Microsoft Entra
This connector can also appear inside a plugin. Connecting it anywhere connects it for your account everywhere, and your connection and your organization’s connector settings apply inside every plugin. See [What are plugins?](https://www.perplexity.ai/help-center/en/articles/2026100701-what-are-plugins.md)
#### **When Both Methods Are Active:**
    Perplexity queries both the local index and SharePoint API concurrently
    Results are re-ranked to prioritize the most relevant sources
    Citations link directly back to SharePoint for full file access
### Indexing Process (High-Precision Search)
#### **File Sync and Storage:**
**File Selection:** User selects files/folders through Perplexity UI
**Download:** Files downloaded from SharePoint via Microsoft Graph API
**Storage:** Raw files stored in AWS S3 with dedicated organizational namespaces
**Parsing:** Text extraction from supported formats (PDF, DOCX, XLSX, PPTX, CSV, TXT, MD, JSON)
**Vectorization:** Content converted to embeddings and stored in Vespa vector database
**Step 6**
**Metadata Indexing:** File metadata (name, path, permissions) indexed for search retrieval
**Step 7**
**Removal:** When a user disconnects SharePoint/OneDrive from Perplexity, they can choose to remove any indexed files
## Security & Compliance Infrastructure
### Permission Enforcement
#### **SharePoint/OneDrive-Side Permissions:**
    If a user loses access to a file in SharePoint/OneDrive, that file is immediately removed from Perplexity
    File deletions in SharePoint/OneDrive trigger immediate removal from Perplexity index
    Users can only search files they have explicit SharePoint/OneDrive permissions to access
#### **Perplexity-Side Permissions:**
    Admins control which users can access connectors via Organization settings
    Files synced to projects are searchable by Project members, but file content requires SharePoint/OneDrive permissions
    Session sharing respects organizational sharing policies set by admins
## Best Practices
### When to Use High-Precision Search (Indexing)
    Project-specific file collections in projects
    Frequently accessed knowledge base documents
    Files requiring deep semantic analysis
    Collaborative team environments with curated content
### When to Use Standard Search (API-Only)
    Searching across vast file repositories (millions of files)
    Strict data residency and minimal data copying requirements
    Exploratory searches across infrequently accessed files
    Organizations with heightened security/compliance constraints
- [Perplexity Enterprise](https://www.perplexity.ai/help-center/en/collections/11312901-perplexity-enterprise.md)
- [Microsoft 365 connector (SharePoint and OneDrive)](https://www.perplexity.ai/help-center/en/articles/12569435-microsoft-365-connector-sharepoint-and-onedrive.md)
- [Connectors & Integrations](https://www.perplexity.ai/help-center/en/collections/18799295-connectors-integrations.md)
- [Google Drive Connector: File Upload Security](https://www.perplexity.ai/help-center/en/articles/13714508-google-drive-connector-file-upload-security.md)
