# Connecting Perplexity with Snowflake
> Connect a Snowflake data warehouse to Perplexity using either User OAuth or a service account, on the Pro, Max, Enterprise Pro, and Enterprise Max plans.
This guide walks Snowflake and Perplexity administrators through connecting a
Snowflake data warehouse to Perplexity, and shows Pro, Max, Enterprise Pro, and
Enterprise Max subscribers how to sign in.
## Overview
The Snowflake connector lets you query data in your Snowflake data warehouse
directly from Perplexity. You can search and combine information across your
Snowflake databases, your other connected apps, and the web without writing SQL
by hand or switching to the Snowflake console.
Connecting Snowflake is done per user. No one else in your organization can
query your data unless you sync it to a shared Project.
> The Snowflake connector is available on the Pro, Max, Enterprise Pro, and
> Enterprise Max plans. Generating a Data Map requires Enterprise Pro or
> Enterprise Max. On every plan, a Snowflake administrator with the ACCOUNTADMIN
> role creates the security integration or service account; on Enterprise plans, a
> Perplexity administrator configures the User OAuth connector once for the
> organization.
## Privacy and data security
The connector queries your Snowflake account under a Snowflake role you
control, so Snowflake privileges are the boundary on what Perplexity can reach.
Grant that role read access only.
* **Access scope** — Each person connects their own account. No one else in
  your organization can query your data unless you sync it to a shared Project.
* **Where data is stored** — Perplexity does not store your Snowflake data.
  Queries run against your own Snowflake account, and the connector adds no
  storage of its own beyond the operational data Perplexity collects to run the
  product.
* **Retention** — The connector does not operate a cache, so there is no
  separate copy of your Snowflake data to retain or delete.
* **Administrator control** — On Enterprise plans, your organization
  administrator can disable the Snowflake connector for your organization, in
  which case it does not appear in your connector settings.
* **Read-only enforcement** — Enforce read-only access through Snowflake
  privileges. Do not grant the role Perplexity uses any write or
  object-creation privilege.
* **Training use** — Data accessed through the Snowflake connector is never
  used to train Perplexity's models or any third-party model.
* **Sub-processors** — Authentication and API traffic for this connector routes
  through Merge Agent Handler, operated by Merge API, Inc., a Perplexity
  sub-processor. The current list is published in the [Perplexity Trust
  Center](https://trust.perplexity.ai/).
* **Encryption** — Connector credentials and connected data are encrypted in
  transit with TLS and at rest with AES-256.
* **Compliance** — Perplexity's controls are audited under SOC 2 Type II.
  Security and compliance documentation is available in the [Perplexity Trust
## How to activate it
### Choosing an authentication method
Perplexity offers two Snowflake connectors. Configure only the one that matches
how your users authenticate.
| Connector | Queries run as | Credential | Audit trail | Use it when |
| **Snowflake (User OAuth)** | Each user's own Snowflake account | OAuth | Attributed per user in Snowflake's audit logs | Recommended for most organizations |
| **Snowflake (Service Account)** | One shared service account | Key pair | Shared identity | Users query through a single account |
*Table 1 — The two Snowflake connectors and when to use each.*
> Perplexity strongly recommends the User OAuth connector. Queries use each
> person's own Snowflake permissions and are attributed to them in Snowflake's
> audit logs.
### Before you start
* You are on the Pro, Max, Enterprise Pro, or Enterprise Max plan.
* On Enterprise plans, your organization administrator has not disabled the
  Snowflake connector.
* Your Snowflake administrator has ACCOUNTADMIN access, or equivalent
  privileges.
* OpenSSL is installed locally, for service account setup only.
### Set up the User OAuth connector
1. Ask your Snowflake administrator to create the security integration. See the
   [Snowflake OAuth security integration
   documentation](https://docs.snowflake.com/en/sql-reference/sql/create-security-integration-oauth-snowflake)
   for additional parameters.
   ```sql theme={null}
   USE ROLE ACCOUNTADMIN;
   CREATE SECURITY INTEGRATION PERPLEXITY_OAUTH
     TYPE = OAUTH
     ENABLED = TRUE
     OAUTH_CLIENT = CUSTOM
     OAUTH_CLIENT_TYPE = 'CONFIDENTIAL'
     OAUTH_REDIRECT_URI = 'https://ah.merge.dev/oauth/callback'
     OAUTH_ISSUE_REFRESH_TOKENS = TRUE
     OAUTH_REFRESH_TOKEN_VALIDITY = 7776000
     OAUTH_USE_SECONDARY_ROLES = IMPLICIT
     COMMENT = 'OAuth security integration for Perplexity';
2. Retrieve the client ID and client secret.
   ```sql theme={null}
   SELECT SYSTEM$SHOW_OAUTH_CLIENT_SECRETS('PERPLEXITY_OAUTH');
3. Enter those credentials in the OAuth setup modal in Perplexity.
> Use OAUTH\_USE\_SECONDARY\_ROLES = IMPLICIT so users can reach their secondary
> roles in addition to their default roles. Use NONE if users should be
> restricted to just their DEFAULT\_ROLE in Snowflake.
### Set up the service account connector
A service account is a dedicated Snowflake user that runs under one specific
role. Everyone using the shared account has the same access, so grant that role
only the data access Perplexity needs.
1. Generate a private key and its matching public key in your local terminal.
   ```bash theme={null}
   openssl genrsa 2048 | openssl pkcs8 -topk8 -inform PEM -out snowflake_computer_key.p8 -nocrypt
   openssl rsa -in snowflake_computer_key.p8 -pubout -out snowflake_computer_key.pub
2. Create a dedicated role and a warehouse, choosing the warehouse size that
   matches your query volume. You can also use an existing warehouse instead of
   creating one.
   ```sql theme={null}
   CREATE ROLE IF NOT EXISTS PERPLEXITY_ROLE
     COMMENT = 'Role for Perplexity service account';
   CREATE WAREHOUSE IF NOT EXISTS PERPLEXITY_WAREHOUSE
     WAREHOUSE_SIZE = 'SMALL'
     AUTO_SUSPEND = 60
     AUTO_RESUME = TRUE
     COMMENT = 'Warehouse for Perplexity queries';
   GRANT USAGE ON WAREHOUSE PERPLEXITY_WAREHOUSE
     TO ROLE PERPLEXITY_ROLE;
3. Create the service account user. Replace the RSA\_PUBLIC\_KEY value with the
   contents of snowflake\_computer\_key.pub, excluding the BEGIN PUBLIC KEY and
   END PUBLIC KEY lines.
   ```sql theme={null}
   CREATE USER PERPLEXITY_USER
     TYPE = SERVICE
     DEFAULT_ROLE = PERPLEXITY_ROLE
     DEFAULT_WAREHOUSE = PERPLEXITY_WAREHOUSE
     COMMENT = 'Service account for Perplexity'
     RSA_PUBLIC_KEY = 'MIIBIjANBgkqhki...your_public_key_here...IDAQAB';
   GRANT ROLE PERPLEXITY_ROLE TO USER PERPLEXITY_USER;
4. Grant access to the data you want Perplexity to query. Replace MY\_DATABASE
   with your own database. These grants provide read access to its existing and
   future schemas, tables, and views. For narrower access, grant permissions on
   specific schemas or objects instead. See the [Snowflake GRANT
   documentation](https://docs.snowflake.com/en/sql-reference/sql/grant-privilege).
   ```sql theme={null}
   GRANT USAGE ON DATABASE MY_DATABASE TO ROLE PERPLEXITY_ROLE;
   GRANT USAGE ON ALL SCHEMAS IN DATABASE MY_DATABASE
   GRANT USAGE ON FUTURE SCHEMAS IN DATABASE MY_DATABASE
   GRANT SELECT ON ALL TABLES IN DATABASE MY_DATABASE
   GRANT SELECT ON FUTURE TABLES IN DATABASE MY_DATABASE
   GRANT SELECT ON ALL VIEWS IN DATABASE MY_DATABASE
   GRANT SELECT ON FUTURE VIEWS IN DATABASE MY_DATABASE
5. If you choose to generate a Data Map in the connector setup flow, grant
   access to the two account usage views it reads. Data Map generation requires
   Enterprise Pro or Enterprise Max. This grant provides broader access to
   Snowflake account metadata, not just these two views, so review it before you
   run it.
   | View | Availability |
   | SNOWFLAKE.ACCOUNT\_USAGE.QUERY\_HISTORY | All editions |
   | SNOWFLAKE.ACCOUNT\_USAGE.ACCESS\_HISTORY | Snowflake Enterprise Edition or higher. On Standard Edition, Perplexity uses QUERY\_HISTORY instead |
   *Table 2 — The account usage views a Data Map reads.*
   ```sql theme={null}
   GRANT IMPORTED PRIVILEGES ON DATABASE SNOWFLAKE
6. Open **Plugins** in the sidebar (or **Customize → Connectors** if you don't see Plugins yet), find **Snowflake (Service Account)** on **Discover** or by search, and open its page.
7. Select **Connect**.
8. Enter your Snowflake account identifier, the username PERPLEXITY\_USER, and
   the private key snowflake\_computer\_key.p8.
9. Select **Allow** to complete setup.
> [!WARNING]
> Keep snowflake\_computer\_key.p8 private. You enter it in Perplexity when
> connecting, and anyone else holding it can query your warehouse as
> PERPLEXITY\_USER. Enforce read-only access through Snowflake permissions: do not
> grant PERPLEXITY\_ROLE write or object-creation privileges.
### Connect your Snowflake account
Once administrator setup is complete, each user connects their own account.
1. Open **Plugins** in the sidebar (or **Customize → Connectors** if you don't see Plugins yet), find **Snowflake (User OAuth)** on **Discover** or by search, and open its page.
2. Select **Connect**.
3. Sign in to Snowflake when prompted.
4. Select **Allow** to complete the connection.
This connector can also appear inside a plugin. Connecting it anywhere connects it for your account everywhere, and your connection and your organization’s connector settings apply inside every plugin. [What are plugins?](https://www.perplexity.ai/help-center/help-center/en/articles/2026100701-what-are-plugins.md)
### How to verify it worked
Open a new session, mention `@Snowflake`, and ask for something small from a
table you can already read in Snowflake, such as a row count. If the answer
comes back without your Snowflake data, your Snowflake role is the first thing
to check: it needs SELECT on the object you named.
## Trying it out
Once Snowflake is connected, mention it in a new session:
* `@Snowflake` How many rows are in the orders table?
* `@Snowflake` Which columns are in the customers table?
* `@Snowflake` List the schemas I can query in MY\_DATABASE
## Permissions and scopes
The connector needs only read privileges. Grant them to a dedicated role rather
than to an existing analyst role.
| Privilege | Granted on | Why the connector needs it |
| USAGE | Warehouse | Run the queries that answer a question |
| USAGE | Database and schemas | Reach the objects it is allowed to query |
| SELECT | Tables and views | Read rows. No write privilege is requested |
| IMPORTED PRIVILEGES | SNOWFLAKE database | Read the two account usage views a Data Map needs. Optional |
| Refresh token | Security integration | Keep a user connected without re-authenticating, for the validity period you set |
*Table 3 — Snowflake privileges the connector requests, and why.*
Snowflake privileges are the enforcement boundary. Whatever the connector is
asked to do, it runs under the role you granted, so a role without write
privileges cannot write.
## Troubleshooting
| Symptom you see | Most likely cause | How to fix it |
| Snowflake is not enabled for your organization, or does not appear in your connector list | On Enterprise plans, an organization administrator disabled it. Otherwise your plan may not include it | On Enterprise plans, contact your organization administrator. Otherwise confirm your plan in **Settings** |
| Sign-in or queries fail, and your Snowflake account restricts inbound connections by IP | The Merge tenant addresses are not allowlisted in your Snowflake network policy | Ask your Snowflake administrator to allowlist the US tenant addresses on the [Merge tenant IP addresses page](https://help.ah.merge.dev/articles/8124222873-merge-tenant-ip-addresses) |
| A user reaches less data than they have been granted in Snowflake | The OAuth session activated only their DEFAULT\_ROLE | Confirm the security integration sets OAUTH\_USE\_SECONDARY\_ROLES = IMPLICIT |
| ACCESS\_HISTORY is unavailable when generating a Data Map | Your Snowflake account is on Standard Edition | ACCESS\_HISTORY needs Enterprise Edition or higher. On Standard Edition, Perplexity uses QUERY\_HISTORY instead |
*Table 4 — Symptom, cause, and fix for the most common Snowflake connector issues.*
For a service account, this example creates a user-level network policy using
the currently published US addresses. Check the Merge tenant IP addresses page
for the current list before applying a policy.
```sql theme={null}
CREATE NETWORK POLICY PERPLEXITY_COMPUTER_POLICY
  ALLOWED_IP_LIST = ('3.216.101.38', '52.20.242.81');
ALTER USER PERPLEXITY_USER
  SET NETWORK_POLICY = PERPLEXITY_COMPUTER_POLICY;
## Frequently asked questions
### What data does this connector access?
The databases, schemas, tables, and views the Snowflake role you granted is
allowed to read. It cannot reach anything that role cannot reach.
### Will my Snowflake data be used to train AI models?
No. Data accessed through the Snowflake connector is never used to train
### Can my administrator restrict who enables this connector?
Yes, on Enterprise plans. An organization administrator can disable the
Snowflake connector for the whole organization, in which case it does not appear
### Can Perplexity write to my Snowflake data?
No, provided you enforce it in Snowflake. Grant the role Perplexity uses only
USAGE and SELECT, and Snowflake rejects any write regardless of what Perplexity
is asked to do.
### Is this connector available on my plan?
Yes, on the Pro, Max, Enterprise Pro, and Enterprise Max plans. Generating a
Data Map requires Enterprise Pro or Enterprise Max.
## Related articles
* [Understanding the Data
  Map](https://www.perplexity.ai/help-center/help-center/en/articles/14017067-understanding-the-data-map.md)
* [Connecting Perplexity with
  Databricks](https://www.perplexity.ai/help-center/help-center/en/articles/14810342-connecting-perplexity-with-databricks.md)
* [Enterprise Connector Troubleshooting
  Guide](https://www.perplexity.ai/help-center/help-center/en/articles/10673201-enterprise-connector-troubleshooting-guide.md)
* [Data Retention and Privacy for Enterprise Organizations and
  Users](https://www.perplexity.ai/help-center/help-center/en/articles/11187708-data-retention-and-privacy-for-enterprise-organizations-and-users.md)
* [Enterprise roles and
  permissions](https://www.perplexity.ai/help-center/help-center/en/articles/11187754-enterprise-roles-and-permissions.md)
## Need more help?
When you write in, include the connector name, the exact error message, the
time it occurred, and the steps from this article that did not resolve it.
> Reach out to your account team or [contact us via **Help > Contact
> Support**](https://www.perplexity.ai/?support=true#settings/account).
> Visit the [Trust Center](https://trust.perplexity.ai/) for
> security and compliance documentation.
- [Connecting Perplexity with Salesforce](https://www.perplexity.ai/help-center/help-center/en/articles/2026101201-connecting-perplexity-with-salesforce.md)
- [Understanding the Data Map](https://www.perplexity.ai/help-center/help-center/en/articles/14017067-understanding-the-data-map.md)
- [Connecting Perplexity with Linear](https://www.perplexity.ai/help-center/help-center/en/articles/12167711-linear-connector-for-enterprise.md)
