# Work with Browsers and Apps
> The floating task bar opens Perplexity while you work in another app. It is available on Windows and Mac.
## **Use the floating task bar**
Use it to start a request or bring relevant desktop context into Perplexity. Open the main app when you need the full task, file, or history view.
On Mac, the default shortcut is pressing the left and right **Command** keys together. Open **Settings → Shortcuts** to view or change the floating task bar and voice shortcuts. On Windows, use **Settings → Shortcuts** to view or change the configured shortcut.
## **Use voice**
Voice lets you speak a request instead of typing it. It is available on Windows and Mac.
On Mac, hold `FN` to start voice mode, then speak the task you want Perplexity to perform. On Windows, use `Ctrl`+`Shift`+`X`.
Open **Settings → Shortcuts** to view or change the shortcut.
To learn what voice mode can do on Mac and the web, see [How to use voice mode on the web and Mac app](https://www.perplexity.ai/help-center/en/articles/2026110501-how-to-use-voice-mode-on-the-web-and-mac-app.md).
## **Use Incognito mode**
Incognito mode keeps a search out of your saved history. Enable it by clicking a button in the top right corner of a new task page.
    Incognito searches are not stored. Once a session is closed, it cannot be recovered.
    Normal mode keeps your signed-in history, so your other searches and threads remain available.
## **Work with Comet**
On Mac, install [Comet](https://www.perplexity.ai/comet) so Perplexity can browse, research, and perform supported web actions. There is no separate Comet connector to enable in the app before first use. When a task needs the local browser, the app requests permission and then uses the installed Comet browser.
## **Work with installed apps**
Installed-app control is available on Mac, not Windows. It can work through supported Mac apps such as Mail, Finder, Slack, Messages, and Notes.
Installed-app control is different from a connector:
    An **installed app** is used through the application running on the Mac.
    A **connector** gives Perplexity access to an account or service through an integration.
- [About the App](https://www.perplexity.ai/help-center/en/articles/19800001-about-the-app.md)
- [Desktop App](https://www.perplexity.ai/help-center/en/collections/19800000-perplexity-desktop-app.md)
- [How to use voice mode on the web and Mac app](https://www.perplexity.ai/help-center/en/articles/2026110501-how-to-use-voice-mode-on-the-web-and-mac-app.md)
- [Supported Browsers for Perplexity Web App](https://www.perplexity.ai/help-center/en/articles/11502647-supported-browsers-for-perplexity-web-app.md)
