# Download and move your organization files
> Download organization files before the repository is retired, then move them to a Project or supported File Connector.
Perplexity is retiring the organization file repository for Enterprise organizations. Files remaining in the repository after October 1, 2026 will be deleted.
**Important:** Download your organization files by **October 1, 2026** to keep them. After downloading, add the files you want to continue using in Perplexity to a Project or use a supported File Connector.
## Why you need to take action
    Keep files your organization still needs before the organization file repository is retired.
    Make shared reference files available to the appropriate people through a Project.
    Use a File Connector when the source files already live in a supported cloud-storage service.
## Before you start
    Confirm which files your organization needs to keep.
    Make sure your role includes the **Download files** permission.
    Decide whether the files should be added to a Project or accessed through a File Connector.
    Confirm who should be able to access the files after they are moved.
Organization administrators should coordinate the migration. Other members can help if their role includes permission to download organization files or manage the destination Project.
## Download your organization files
Sign in to Perplexity on the web.
Open **Settings**, select **Organization**, then open **Files**.
Select **Download your org files**. Perplexity prepares a ZIP archive and downloads it when it is ready.
Open the archive and confirm the files are complete and readable.
Store the downloaded copy in an approved location until the migration is complete.
**Important:** Downloading the ZIP archive does not automatically add the files to a Project or connect them to Perplexity. Complete one of the following migration options if you want to continue using the files in Perplexity.
## Add downloaded files to a Project
Create a Project or open an existing Project.
Open the Project's **Files** tab.
Upload the files you downloaded from the organization file repository.
Confirm that all required files appear in the Project.
Share the Project with the people who should be able to use the files.
Files added to a Project are copies and follow that Project's permissions and retention behavior. Updating a file outside Perplexity does not automatically update the Project copy.
## Use a File Connector
If the source files already live in a supported cloud-storage service, connect that service instead of maintaining static copies. Supported File Connectors include Google Drive and Microsoft 365 (SharePoint and OneDrive).
Open **Plugins** in the sidebar (or **Customize → Connectors** if you don't see Plugins yet).
Find the service you want to use on **Discover** or by search, then select **Connect**.
Sign in to the service and review the requested permissions.
Return to the **Installed** tab and confirm that the service shows **Connected**.
File Connectors use the permissions of the connected account. A person can search or open only content their connected account is authorized to access. If you import a connector file into a Project, the imported file becomes a separate copy and follows the Project's permissions and retention behavior.
## Choose the right migration option
    **Use a Project** for a shared, curated collection of files that should provide persistent context for a specific team or initiative.
    **Use a File Connector** when files should remain in the source service and access should follow the connected account's permissions.
    **Use both** when a team needs a stable Project copy of selected files while other content remains available through the connected service.
## Verify the migration
    Open the downloaded ZIP archive and confirm every required file is readable.
    Confirm that every required file is available in its new destination.
    Check that the intended people can access the Project or connected service.
    Ask a question about one of the moved files and confirm that the answer cites the expected content.
Keep the downloaded copy until your organization has confirmed that the migration is complete.
## Frequently asked questions
> [accordion] What happens after October 1, 2026?
> Files remaining in the organization file repository after October 1, 2026 will be deleted. Download every file your organization needs before the deadline.
> [accordion] Does this affect files in Projects?
> No. Project files are separate from the organization file repository and continue to follow their Project's permissions and retention behavior.
> [accordion] Does this affect files in connected services?
> No. Files remain in their source service. Their availability in Perplexity depends on the File Connector and the connected account's permissions.
> [accordion] Do I need to take action if my organization does not use organization files?
> No. You do not need to take action if the organization file repository does not contain files your organization needs to keep.
> [accordion] Does downloading a file keep it available as a source in Perplexity?
> No. Downloading preserves a copy outside the organization file repository. To continue using the file in Perplexity, add it to a Project or use a supported File Connector.
> [accordion] Who should move the files?
> Organization administrators should coordinate the migration. Members with permission to download organization files or manage the destination Project can also help.
> [accordion] What if I cannot download the files?
> Ask an organization administrator to confirm that your role includes the **Download files** permission. If the export still fails, contact Perplexity Support before October 1, 2026.
## Related articles
    [What are Projects?](https://www.perplexity.ai/help-center/en/articles/10352961-what-are-projects.md)
    [Introduction to File Connectors for Enterprise Organizations](https://www.perplexity.ai/help-center/en/articles/10672063-introduction-to-file-connectors-for-enterprise-organizations.md)
    [Enterprise file limits](https://www.perplexity.ai/help-center/en/articles/12009761-enterprise-file-limits.md)
    [Security and Privacy with File Uploads](https://www.perplexity.ai/help-center/en/articles/10354810-security-and-privacy-with-file-uploads.md)
    [Enterprise roles and permissions](https://www.perplexity.ai/help-center/en/articles/11187754-enterprise-roles-and-permissions.md)
Need more help? Reach out to your account team or [contact us via Help > Contact Support](https://www.perplexity.ai/?support=true#settings/account).
- [Why can't I see focus mode on my search bar?](https://www.perplexity.ai/help-center/en/articles/10354759-why-can-t-i-see-focus-mode-on-my-search-bar.md)
- [Enterprise Security Hub Settings](https://www.perplexity.ai/help-center/en/articles/10517443-enterprise-security-hub-settings.md)
- [Enterprise file limits](https://www.perplexity.ai/help-center/en/articles/12009761-enterprise-file-limits.md)
- [Security and Privacy with File Uploads](https://www.perplexity.ai/help-center/en/articles/10354810-security-and-privacy-with-file-uploads.md)
