# Where did Connectors and Skills go?
> Connectors and Skills are now on the Plugins page in Perplexity Computer. Learn what moved and where to manage connections, skills, and Memory.
The **Connectors** and **Skills** pages have moved into a single **Plugins** page. Nothing about your account has changed: your connected connectors are still connected, your installed skills are still installed, and old links still take you to the right place.
> If you don't see Plugins in the sidebar yet, keep using **Customize → Connectors** and **Skills**. Everything there works as before.
## What changed
    **One page instead of two.** Connectors, skills, and the new [plugins](https://www.perplexity.ai/help-center/help-center/en/articles/2026100701-what-are-plugins.md) are all on the **Plugins** page. Open it from **Plugins** in the sidebar.
    **Customize is now Plugins.** The sidebar item that used to be called **Customize** is now **Plugins**. **Memory** has moved to **Settings**.
    **New tabs.** **Discover** replaces the separate connector and skill catalogs. **Installed** replaces **My Skills** and your list of connected connectors. If you belong to an organization, the **Organization** tab replaces the organization skills tab.
    **New categories.** Connectors and skills are grouped by the kind of work they support rather than by type, so a category can include plugins, connectors, and skills together.
    **One place to add your own.** **Add custom** replaces the separate create and upload buttons for connectors and skills, and also lets you upload a plugin.
## What stayed the same
    Your connections were not disconnected and your skills were not uninstalled. They are listed on the **Installed** tab.
    Connectors and skills still work on their own. You can connect a connector or install a skill without installing a plugin.
    Each connector and skill still has its own page with the same name, description, tools, and permissions.
    Links to the old **Connectors** and **Skills** pages, including links to a specific connector or skill, redirect to the matching page under Plugins. Update any bookmarks when convenient.
    For Enterprise organizations, administrators manage connectors on **Organization settings → Connectors** and plugins and skills on **Organization settings → Plugins and skills**. Connector permissions apply inside plugins the same way they apply everywhere else.
## Where to find things now
    **Connect or reconnect a connector:** open the **Installed** tab, or search for the connector and open its page. The **Manage connectors** link in your settings and in the sources menu now opens this tab.
    **Turn a skill off or on:** open the **Installed** tab, switch to **Skills**, and use the **Enabled** switch next to the skill.
    **Create or upload a skill:** select **Add custom** on the Plugins page.
    **Add a custom remote connector:** select **Add custom** on the Plugins page. See [Adding Custom Remote Connectors](https://www.perplexity.ai/help-center/help-center/en/articles/13915507-adding-custom-remote-connectors.md).
    **Manage Memory:** open **Settings** and select **Memory**. See [Memory](https://www.perplexity.ai/help-center/help-center/en/articles/10968016-memory.md).
## I don't see the Plugins page
Plugins are rolling out gradually, starting with individual plans and Self-Serve Enterprise organizations, and are coming soon to sales-assisted Enterprise plans. If you still see **Customize → Connectors** and **Skills**, you don't have Plugins yet. Everything there works as before, and your connectors and skills will carry over when Plugins becomes available.
## Related articles
    [What are plugins?](https://www.perplexity.ai/help-center/help-center/en/articles/2026100701-what-are-plugins.md)
    [Find, install, and remove plugins](https://www.perplexity.ai/help-center/help-center/en/articles/2026100702-find-install-and-remove-plugins.md)
    [How to use Computer Skills](https://www.perplexity.ai/help-center/help-center/en/articles/13914413-how-to-use-computer-skills.md)
    [Troubleshooting connectors](https://www.perplexity.ai/help-center/help-center/en/articles/2026091802-troubleshooting-connectors.md)
## Need more help?
[Contact us via **Help > Contact Support**](https://www.perplexity.ai/?support=true#settings/account). Include the task link if your question is about a specific Computer task.
- [Computer](https://www.perplexity.ai/help-center/help-center/en/collections/18534886-computer.md)
- [Find, install, and remove plugins](https://www.perplexity.ai/help-center/help-center/en/articles/2026100702-find-install-and-remove-plugins.md)
- [Troubleshooting plugins](https://www.perplexity.ai/help-center/help-center/en/articles/2026100803-troubleshooting-plugins.md)
- [What are plugins?](https://www.perplexity.ai/help-center/help-center/en/articles/2026100701-what-are-plugins.md)
