Best Rated Mascaras: Top Picks for Volume and Length
Mascara is a crucial element in many makeup routines, with countless options available to enhance lash volume, length, and curl. According to beauty experts and consumer reviews, top-rated mascaras include Benefit's Fan Fest Fanning & Volumizing Mascara, Essence Lash Princess False Lash Effect, and Maybelline's Sky High Mascara, each offering unique benefits for different lash types and desired looks.
Mascara Guide: Choosing the Right Type for Your Lash Goals
Mascara comes in various types, each designed to address specific lash needs and desired effects. Here's a concise overview of the main types of mascara:
Each type of mascara offers unique benefits, allowing users to choose the best option for their lash goals and lifestyle needs. Some mascaras combine multiple features, such as volumizing and lengthening, to provide comprehensive lash enhancement.
Type | Description |
Volumizing | Adds thickness to lashes, making them appear fuller and bolder 1 2 |
Lengthening | Extends the length of lashes, ideal for those with shorter lashes 1 2 |
Curling | Lifts and curls lashes, maintaining the curl throughout the day 1 2 |
Waterproof | Resistant to water, sweat, and tears, suitable for long-wear or humid conditions 1 2 |
Tubing | Forms tubes around each lash for smudge-proof, long-lasting wear, and easy removal with warm water 3 4 |
Clear | Holds lashes in place after styling, providing a wet and glossy look 1 |
Fiber | Contains tiny fibers that adhere to lashes, adding length and volume 2 4 |
Top Features to Consider When Choosing the Best Mascara for Your Needs
When choosing a mascara, several key features can significantly impact its performance and suitability for your needs. Here's a breakdown of important factors to consider:
The right combination of these features can help you achieve your desired lash look while also caring for your lashes. For instance, a volumizing mascara with a curved brush and nourishing ingredients might be ideal for those seeking dramatic, healthy-looking lashes
Feature | Considerations |
Formula | Dry formulas hold curl better, wet formulas add more volume |
Brush Type | Molded silicone for lengthening, hourglass shape for volumizing |
Ingredients | Look for nourishing components like jojoba oil, vitamin E, or castor seed oil |
Longevity | Opt for long-wearing, flake-free, and smudge-resistant formulas |
Water Resistance | Choose waterproof for humid conditions or long wear 1 |
Removal Ease | Consider tubing mascaras for easy removal with warm water 2 |
. Remember to consider your lifestyle and lash needs when selecting a mascara to ensure the best results.4 sources
Best Mascaras: Our Top Picks for Voluminous and Lengthy Lashes
Liquid Lash™ Extensions Mascara
4.4
$26.00
Voluminous Mascara
$10.95
Maybelline Lash Sensational Sky High Volumizing and Thickening Mascara
$13.21
$14.95
THE MASCARA
4.3
$28.00
CHANEL Le Volume De Mascara #10 Noir
$78.99
$156.99
6
White Spectra Lash - Mascara - Glisten Cosmetics
$12.00
7
Benefit Fan Fest Mascara 8.5g
$35.34
Buy this if you want dramatically lengthened lashes with a long-lasting, smudge-proof formula that's easy to remove
- Dramatic lengthening
- Long-lasting wear
- Easy removal
- Potential lash damage
- Clumping
Voluminous Mascara
$10.95
Buy this if you want a professional-quality mascara that delivers dramatic volume and length without clumping, at an affordable price
- Dramatic volume
- Smooth application
- Long-lasting
- Potential flaking
15% off
$12.70
$14.95
Buy this if you want a budget-friendly mascara that delivers dramatic length and buildable coverage for a false lash effect without the high-end price tag
- Exceptional Length
- Buildable Formula
- Flexible Brush
- Potential Clumping
- Volume vs Length
THE MASCARA
Buy this if you want a high-performance, waterproof mascara that adds volume and length while nourishing your lashes, and you don't mind paying a premium for vegan, cruelty-free formulation
- Smudge-proof
- Volumizing and lengthening
- Lash-nourishing
- Price
49% off
$78.99
$156.99
Buy this if you want a high-end mascara that delivers dramatic volume and length with long-lasting wear, and are willing to invest in a premium beauty product
- Long-lasting wear
- Volume and length
- Inconsistent quality
- High price
$9.50
Buy this if you want to experiment with bold, colorful lash looks and are willing to practice application techniques for best results
- Vibrant Color
- Lengthening Effect
- Application Difficulty
$32.00
Buy this if you desire dramatically voluminous, fanned-out lashes with long-lasting curl and are willing to perfect your application technique
- Volume
- Long-lasting
- Eye-opening effect
- Application
- Smudging
How to Apply Mascara Like a Pro: Expert Tips for Stunning Lashes
youtube.com
Watch
Mastering the art of mascara application can significantly enhance your lash game. Here are some expert tips to achieve fuller, longer-looking lashes:
- Warm up the mascara tube by placing it in your bra while doing the rest of your makeup to ensure a smoother application.1
- Curl your lashes before applying mascara to maximize lift and length.2
- Start by wiggling the wand at the base of your lashes, then sweep upwards in a zig-zag motion for added volume.23
- For precision, turn the wand vertically to coat smaller lashes and reach corner lashes.24
- Apply mascara to the tips of your lashes first, then work your way to the roots for a more natural look.1
- Use a clean mascara wand or lash comb to separate lashes and remove clumps.1
- For extra drama, apply mascara to both the top and underside of your lashes.4
- To avoid smudges, use a business card behind your lashes as a shield during application.4
- Let each coat dry partially before applying the next to build volume without clumping.1
- Clean up any mistakes with a cotton swab dipped in makeup remover or moisturizer.4
Wrapping Up: Best Mascaras for Stunning Lashes
nypost.com
When selecting the best mascara, consider your specific needs and preferences. Waterproof mascaras like L'Oreal Voluminous Lash Paradise and Maybelline Sky High Lash Sensational offer excellent longevity for special occasions or humid conditions
. For everyday wear, non-waterproof formulas may be gentler on lashes. Brown mascara provides a softer look for natural makeup, while black shades offer more drama1
. Key factors to consider include formula type (volumizing, lengthening, or curling), brush shape, and ingredients3
. For those with straight lashes, a lash curler paired with a curling mascara can create a lasting lift. Clean formulas with nourishing ingredients are ideal for sensitive eyes or daily use3
. Ultimately, the best mascara depends on individual eye shape, lash type, and desired effect, whether it's subtle definition for everyday wear or voluminous lashes for a special event4
. Remember to use a gentle eye makeup remover to protect lashes when removing waterproof formulas1
.5 sources
What are the top-rated brown mascaras for everyday use
Which waterproof mascara provides the best volume and curl
How do different mascara formulas affect lash health
What's the best mascara for sensitive eyes
Are there any mascaras that work well for both everyday wear and special occasions
Discover the Top Pens of 2024: Our Expert Recommendations
The world of pens is vast and diverse, offering a wide range of options for every writing need and preference. As we enter 2024, the market continues to evolve with innovative designs and improved ink technologies, making it challenging yet exciting for enthusiasts and casual users alike to find their perfect writing instrument.
6,227
Best Lip Balms of 2024: Keep Your Lips Soft and Hydrated
The best lip balms of 2024 offer a range of options to soothe, protect, and nourish dry lips, with top picks including Everyday Humans Milky Lip Balm for SPF protection and Lanolips 101 Ointment for intense hydration, according to expert reviews and user experiences.
3,230
Best Night Creams of 2024: Our Top Picks
Night creams are an essential part of a skincare routine, offering targeted nourishment and repair while you sleep. According to dermatologists and beauty experts, the best night creams for women contain ingredients like retinol, hyaluronic acid, and antioxidants to address concerns such as aging, dryness, and uneven skin tone.
2,790
Best Wrinkle Eye Creams of 2024: Our Top Picks
Eye creams have become an essential part of many skincare routines, with numerous options available to target fine lines, wrinkles, and other signs of aging around the delicate eye area. According to dermatologists and beauty experts, the best eye creams for wrinkles contain proven ingredients like retinol, hyaluronic acid, and peptides to help smooth, hydrate, and rejuvenate the skin.
3,024
