  • Feeling the Slope
  • Determining Slope Percentage
  • Visualizing Aim Point
  • Starting the Putt
How Does Aim Point Work in Putting?
Aimpoint Putting is a popular method used by golfers to read greens and determine the optimal aim point for their putts. By combining the feel of the green's slope with a precise visualization technique, Aimpoint helps players of all skill levels improve their putting accuracy and consistency.
golfexcellence
gearssports.com favicon
gearssports
Does Aimpoint Putting Actually Work? Yes! Here's How to Use It
skillest.com favicon
skillest
A Comprehensive Guide to AimPoint Golf Putting - Skillest Blog
thediygolfer.com favicon
thediygolfer
Aimpoint Express for Beginners - The DIY Golfer
youtube
Does AimPoint Work? And How To Read Greens with ... - YouTube
golf.com
golf.com
Feeling the Slope
youtube.com
youtube.com
Watch
The first step in the Aimpoint Putting method is to feel the slope of the green. To do this, stand at the midpoint of the putt, straddling the line between the ball and the hole. Shift your weight from one foot to the other, using your body to sense the incline of the green.1 This technique allows golfers to estimate the percentage of slope, which typically ranges from 0.5% to 3%.2 More experienced players can better discern smaller slope differences through this process.2
golfwrx.com
golfwrx.com
golfwrx.com
Based on the felt slope, golfers estimate the percentage of slope, typically ranging from 0.5% to 3%.1 To practice this skill:
  • Use a digital level to find spots on the green with various slopes (e.g., 0.5%, 1%, 1.5%, 2%, 2.5%, 3%)
  • Rotate randomly between these spots, training your brain to identify each slope percentage
  • Employ a "guess and check" method by estimating the slope, then verifying with the digital level2
With consistent practice, golfers can improve their ability to accurately determine slope percentages using their feet and body.2
oldduffergolf.com
oldduffergolf.com
oldduffergolf.com
To visualize the aim point, stand behind the ball and close one eye. Lift your hand, aligning your pointer finger just outside the edge of the hole. Hold up the number of fingers corresponding to the slope percentage you felt – one finger for each percent. For example, if you felt a 2% slope, hold up two fingers with your pointer finger just outside the hole. The outermost finger represents your precise aim point.12 This visualization technique allows golfers to determine the correct starting line for their putt, accounting for the break caused by the green's slope.3
Starting the Putt
golfdigest.com
golfdigest.com
golfdigest.com
After determining the aim point, set up to the ball and align your putter with the visualized target. Execute the putt with a straight stroke, allowing gravity to curve the ball into the hole based on the green's slope.1 Proper speed control is crucial for success, as hitting the putt too softly or firmly will cause it to miss, even if aimed correctly.2 With practice and patience, golfers can master the Aimpoint method, improving their green reading skills and overall putting performance.34
how does Aimpoint Putting compare to other putting techniques
what are the key differences between Aimpoint Putting and traditional putting methods
how can I integrate Aimpoint Putting into my existing putting routine
Dechambeau and Mickelson miss cut at Oakmont US Open
Defending U.S. Open champion Bryson DeChambeau and six-time major winner Phil Mickelson both missed the cut at Oakmont, with DeChambeau shooting a 7-over 77 on Friday to finish 10 over through two rounds, while Mickelson, in potentially his last U.S. Open appearance, finished at 8 over.
88
Victor Perez makes history with second hole-in-one at Oakmont
French golfer Victor Perez made history at the 2025 U.S. Open by recording just the second hole-in-one ever at Oakmont during the championship, sinking a 7-iron shot on the 192-yard par-3 sixth hole during Friday's second round and celebrating with a memorable chest bump that helped move him to +1 for the tournament after previously struggling with a triple-bogey.
376
Solar Orbiter captures first images of the Sun’s elusive south pole
The European Space Agency's Solar Orbiter has captured humanity's first-ever images of the Sun's south pole, providing an unprecedented view of our star from a perspective never before seen by human eyes, as reported by Space.com and IFLScience. These groundbreaking observations, taken in March 2025 from 15 degrees below the solar equator, mark the beginning of a new era in solar science as...
1,899
Finance professor tests AI’s ability to replace stock analysts
According to reports from Morningstar, University of Florida finance professor Alejandro Lopez-Lira has been conducting experiments with AI models like ChatGPT, DeepSeek, and Grok to evaluate their stock-picking capabilities, finding impressive results that suggest these technologies could potentially automate many tasks currently performed by financial analysts.
163,879
