Action | Description |
Unplug immediately | Remove the charging cable as soon as you see the moisture warning to prevent potential damage.12 |
Wipe device | Use a soft, dry cloth to remove any visible moisture from the phone's exterior.2 |
Shake gently | Carefully shake the device 5-10 times with the port facing downward to remove excess moisture.2 |
Air dry | Place the phone in a well-ventilated area or use a fan to aid drying.2 |
Wait | Allow 1-2 hours for natural evaporation before attempting to charge again.1 |
Avoid heat | Do not use hair dryers or place the device in rice, as these methods can cause damage.3 |
Method | Description |
Compressed air | Use short bursts to blow out loose debris 1 |
Cotton swab | Gently clean the port with a dry cotton swab 1 |
Toothpick | Carefully remove visible lint or debris 1 |
Rubbing alcohol | Apply a small amount to a cotton swab for stubborn residue 2 |
Charging port cleaning kit | Use specialized tools for thorough cleaning 3 |
Solution | Steps |
Clear USB cache | Settings > Device care > Battery > 3-dot menu > Advanced settings > Clear USB cache 1 |
Disable fast charging | Settings > Device care > Battery > Charging > Turn off Fast charging 2 |
Update software | Settings > About Phone > Software Updates > Download and Install 3 |
Clear cache partition | Power off device, hold Power + Volume Up, select "Wipe cache partition" in recovery menu 3 |
