  • Step#1: Perform Soft Reset
  • Step #2: Check Audio Settings
  • Step #3: Check External Devices
  • Final Thoughts and Advice
  • Step #4: Run Self Diagnostics Test
  • Troubleshooting Guides (Videos)
How to Fix a Sony TV with No Sound: Step-By-Step Guide
Sony BRAVIA TVs, while known for their quality, can sometimes experience issues. Based on reports from Sony, most problems can be resolved through simple troubleshooting steps, starting with a soft reset using the remote control or power cycling the device.
jenengevik
helpguide.sony.net favicon
helpguide.sony
If a full reset (restart) of the TV is required - Sony Corporation
sony.com favicon
sony
BRAVIA TV troubleshooting guide | Sony USA
sony-asia.com favicon
sony-asia
BRAVIA TV Troubleshooting Guide | Sony AP
stock.adobe.com
stock.adobe.com
reddit.com
reddit.com
reddit.com
Performing a soft reset is often the first and most effective step in troubleshooting Sony TV issues, including audio problems. Here's how to perform a soft reset on your Sony TV:
  1. Press and hold the power button on the remote control for about 5 seconds until the TV restarts.1
  2. If the above doesn't work, unplug the TV's power cord from the electrical outlet for 30 seconds, then plug it back in.23
  3. For TVs with only one button, press and hold the power button on the TV itself while plugging the power cord back in, continuing to hold until a white LED light appears (usually within 10-30 seconds).34
  4. For TVs with three buttons, simultaneously press and hold the power and volume down buttons on the TV while plugging the power cord back in, continuing to hold until a green LED light appears.3
If the soft reset doesn't resolve the issue, proceed to check the audio settings and connections as outlined in the subsequent steps.
sonylatvija.com favicon
Sony TVs offer various audio settings that can be adjusted to resolve sound issues. Here's a quick guide to checking and adjusting these settings:
SettingAction
VolumeEnsure TV and connected devices are not muted or set to low volume
Audio OutputVerify correct audio output is selected (TV speakers, sound system, etc.)
Sound ModeTry different sound modes (Standard, Cinema, Music)
EqualizerAdjust bass, treble, and balance settings
Digital Audio OutCheck if set to PCM for compatibility with all devices
Audio DescriptionDisable if unintentionally activated
If audio issues persist after adjusting these settings, check all cable connections between the TV and external audio devices. Ensure HDMI or optical cables are securely plugged in and try different ports if available.12 For smart TVs, check if the issue occurs in all apps or just specific ones, as this can indicate whether the problem is with the TV hardware or a particular streaming service.3
sony.com favicon
Sony TVs may experience various screen and picture issues that can be resolved through systematic troubleshooting. Here's a table summarizing common screen problems and their potential solutions:
Screen IssueTroubleshooting Steps
Lines on screenCheck if issue occurs in TV menu; if so, restart TV or perform self-diagnostics. If not in menu, check broadcast signal or connected devices.123
Blurred screenReset picture settings, update TV software, check for RF interference, adjust antenna (if applicable).123
No display/blank screenPerform soft reset, check power connections, verify input source.45
Abnormal colorsReset picture settings, check cable connections, update TV software.1
Double or ghost imagesAdjust antenna direction, check for signal reflections from nearby structures.123
If these steps don't resolve the issue, consider checking for physical damage, running built-in diagnostics tests, or contacting Sony support for further assistance.415
sony.com favicon
sony.co.uk favicon
When troubleshooting Sony TV issues, it's important to approach the problem systematically. If the steps outlined in this guide don't resolve your audio problem, remember that Sony provides comprehensive support resources. Visit Sony's official support website to access model-specific troubleshooting guides, firmware updates, and contact information for customer service12. For complex issues or potential hardware failures, professional servicing may be necessary. Always ensure your TV's software is up-to-date and consider the warranty status before seeking repairs3.
DIY solutions can often fix common problems like tinny sound or a clicking sound. However, for persistent issues that affect theatrical sound quality, such as a lack of dynamic sound or issues with sound louder settings, reaching out to Sony's expert technicians is advisable. They can help maintain your TV's optimal performance and longevity, ensuring features like virtual surround sound processing and MTS (Multi-Channel Television Sound) remain effective.
For more complex audio concerns, such as achieving a balanced sound with a connected third-party sound bar or adjusting the subwoofer sound for a brighter effect, expert assistance may be necessary. Sony's technicians can guide you through setting up external sound modes, selecting the right preset sound modes, and ensuring your surround sound mode or untouched sound settings are correctly configured. This professional support can help you achieve an awesome sound experience, even with complicated sound setups. Don't hesitate to seek help to keep your connected sound systems performing at their best4.
sony.com favicon
sony-latin.com favicon
Sony BRAVIA TVs come equipped with a built-in Self Diagnostics feature that can help identify and resolve basic setup and configuration issues. This tool is particularly useful for troubleshooting picture and sound problems. Here's a quick guide on how to run the Self Diagnostics test on your Sony TV:
StepAction
1Press the HOME button on your remote control
2Navigate to and select "Help" from the menu
3Choose "Customer Support"
4Select "Self Diagnostics"
5Click on "Start Self Diagnostics"
6If no error is detected, select "Check Picture/Sound" to continue
7Follow on-screen instructions to complete the test
If the test doesn't detect any issues but you're still experiencing problems, it's recommended to check external device connections and settings123. For specific issues with connected devices, you can also run a diagnostic check by selecting "External Device Symptoms" from the Customer Support menu4. Remember that the exact steps may vary slightly depending on your TV model and software version1.
sony.com favicon
Where can I find video tutorials for fixing common TV issues
Are there video tutorials for troubleshooting specific TV models
What are the best websites for TV repair video tutorials
Can I find video tutorials for advanced TV settings and features
Are there YouTube channels dedicated to TV troubleshooting video tutorials
Google brings Gemini AI to Home broadcast feature
Google began rolling out Gemini app integration with Google Home's broadcast feature on Monday, allowing users to send voice messages to Nest speakers and smart displays without relying on the legacy Google Assistant. The update represents the latest step in Google's broader transition from Assistant to its AI-powered Gemini across all devices and platforms. The rollout comes months ahead of...
819
Apple users have hours left to claim Siri settlement cash
Apple users have less than 24 hours remaining to file claims for their share of a $95 million settlement over allegations that Siri secretly recorded private conversations, with the deadline set for tomorrow, July 2. The settlement stems from a 2019 class-action lawsuit that accused Apple of programming its voice assistant to capture conversations even when users hadn't intentionally activated...
36,885
Trump blasts AT&T after call with faith leaders delayed
President Donald Trump publicly blamed AT&T on Monday for technical difficulties that delayed a conference call with thousands of religious leaders nationwide, threatening to use a different telecommunications provider for future events. The incident highlights Trump's willingness to leverage his presidential platform to criticize private companies, while underscoring the administration's...
14,611
Trump, Paramount seek pause in $20B lawsuit for settlement talks
President Donald Trump and Paramount Global have requested a pause in all legal proceedings in their $20 billion lawsuit until Thursday, telling a Texas court they are engaged in "advanced settlement negotiations" to resolve the dispute over CBS News' editing of a Kamala Harris interview. The parties filed a joint motion Monday stating that "good cause to stay all proceedings exists because the...
4,178
