  • Design and Construction
  • Dimensions and Installation
  • Versatility and Use Cases
  • Pricing and Customer Feedback
Rubber Corner Guard
The Rubber Corner Guard is a versatile safety product designed to protect corners in high-traffic areas, offering durable impact resistance and enhanced visibility through its black and yellow striped design.
altamira
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Crafted from high-quality rubber, this corner guard boasts exceptional durability and longevity. Its distinctive black and yellow striped pattern serves a dual purpose: enhancing visibility and providing a visual alert to potential corner hazards. The design incorporates molded reflective tape, significantly improving driver awareness and overall safety in low-light conditions.1
  • Made of impact-resistant rubber for structural integrity
  • Features 6 mounting holes for secure, permanent installation
  • Resistant to chemicals, weather, and corrosion
  • Helps reduce workplace injuries by protecting corners and equipment
1 source
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Measuring 31.5 inches in length, 5 inches in width, and 0.32 inches in height, this corner guard is designed to provide ample coverage for standard 90-degree corners1. Installation is straightforward, with the product featuring 6 pre-drilled mounting holes. For optimal security, it's recommended to use screws with plastic anchors at least 3 cm long, although hardware is not included with the purchase1. The guard's lightweight construction, weighing just 4 pounds, allows for easy handling during the installation process.
1 source
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Designed for both indoor and outdoor applications, this corner guard excels in diverse environments ranging from warehouses and offices to parking garages. Its versatility extends to protecting door frames, machinery, and any 90-degree corner susceptible to impact damage1. The product's weather-resistant properties make it an ideal choice for outdoor installations, while its chemical resistance ensures longevity in industrial settings. This adaptability, combined with its high-visibility design, makes it an essential safety feature in various commercial and residential spaces, effectively reducing the risk of accidents and property damage.
1 source
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Available at $17.25 each for orders of 1-49 pieces and $14.98 each for 50 or more, the Rubber Corner Guard offers volume-based pricing1. Special discounts are available for bulk orders exceeding 100 pieces. Customer feedback has been positive, with users praising its effectiveness in various settings. Owen Grant found it useful for protecting car doors in a driveway, while Daniel Castro appreciated its durability in a store parking lot1. Juan Molina highlighted the ease of installation and peace of mind it provided in a shared apartment garage, demonstrating the product's versatility across different environments.
1 source
What do customers say about the durability of the rubber corner guards
Are there any complaints about the installation process
How do customers rate the visibility improvement from the reflective tape
Have there been any issues with the corner guards in extreme weather conditions
What do customers think about the value for money of the rubber corner guards
Rigging: Essential for Construction
Rigging, the process of preparing, lifting, and securing heavy objects, plays a crucial role in the construction industry. Proper rigging techniques ensure the safe and efficient movement of materials, machinery, and equipment on construction sites, minimizing the risk of accidents and injuries while improving productivity.
7,840
Floor Protection for Painters
Professional painters employ a variety of floor protection methods to safeguard surfaces during their work, ranging from durable drop cloths and rosin paper to specialized adhesive plastic sheeting and heavy-duty options like Ram Board. These materials are crucial for preventing damage from paint spills, splatters, and foot traffic. The choice of floor protection depends on factors such as the project's scale, flooring type, and the level of protection required. This page delves into the...
6,196
