Rubber speed bumps offer an efficient and versatile solution for traffic control, combining durability with easy installation. These safety devices, available in various sizes and configurations, can typically be installed in just a few hours, making them a popular choice for enhancing road safety in diverse settings.
Crafted from vulcanized rubber, these speed bumps are engineered to withstand heavy traffic conditions and resist weather, UV light, and chemicals1. The robust construction ensures longevity, with protective end caps shielding section ends from wear and tear. Each 6-foot section weighs 48 lbs, striking a balance between durability and manageability for easy installation by a single person1. The product's versatility allows it to function as both a speed bump and a 2-channel cable protector, making it suitable for various applications including residential areas, commercial settings, parks, and school zones1.
Equipped with embedded EPDM rubber strips in vibrant yellow, these speed bumps ensure excellent visibility even in low-light conditions. Molded-in cat eye reflectors further enhance their conspicuousness, effectively alerting drivers to slow down1. This high-visibility design is crucial for safety, as it:
Helps drivers notice the speed bump from a distance
Reduces the risk of sudden braking or accidents
Maintains effectiveness in various weather conditions
Contributes to slowing vehicles to a safe speed of approximately 5 MPH1
These visibility features make the speed bumps particularly suitable for areas with high pedestrian traffic or locations requiring extra caution, such as school zones and parking lots.
The installation process for rubber speed bumps is straightforward and can typically be completed in just a few hours. It involves three main steps: positioning and marking the location, drilling holes for anchoring, and securing the speed bump with provided hardware.1 This efficient installation method contributes to the popularity of rubber speed bumps as a quick traffic-calming solution. Unlike concrete alternatives that may require a day or more for curing, rubber speed bumps can be used immediately after installation, minimizing disruption to traffic flow.2
Available in various configurations to suit different needs, these speed bumps range from 6 to 25 feet in length, all maintaining a consistent height of 2 inches and width of 12 inches. Pricing varies based on size and quantity, with discounts offered for bulk orders of 50 units or more. For instance, a 6-foot speed bump costs $74.00 for orders of 1-49 units, reducing to $68.50 for 50 or more units. Larger options, such as the 25-foot speed bump, are priced at $372.92 for smaller orders, decreasing to $365.46 for bulk purchases1. Special discounts are available for orders exceeding 100 pieces, emphasizing the product's scalability for large-scale traffic management projects.
