  • Premium Speed Bumps Features
  • Heavy-Duty Speed Bumps
  • Specialized Speed Bumps
  • Low Profile Speed Humps
Speed Bumps and Humps
Unimat Traffic offers a diverse range of speed bumps and humps designed to enhance road safety and control traffic in various settings, from residential areas to industrial zones, providing durable and customizable solutions for effective vehicle speed reduction.
altamira
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Designed for versatility and effectiveness, premium speed bumps offer a robust solution for traffic calming in diverse environments. These high-visibility devices feature durable bright yellow rubber construction with protective end caps to prevent wear and tear1. Ideal for residential areas, commercial zones, parks, and school zones, they excel at slowing down vehicle traffic without causing excessive disruption1. While mounting screws are typically not included, customers have the option to add them to their order, specifying whether they need hardware for asphalt or concrete installation1.
1 source
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Engineered for high-traffic areas and demanding environments, heavy-duty speed bumps offer superior durability and performance. The 6' Super HD model stands out with its robust construction and included mounting hardware, a unique offering in the market1. These traffic calming devices are versatile enough for use in various settings, from bustling commercial zones to busy school areas. Their bright yellow sections ensure high visibility, enhancing safety for both drivers and pedestrians1. Unlike standard models, these heavy-duty variants are designed to withstand constant use by larger vehicles, making them ideal for industrial areas and logistics hubs where truck traffic is common.
1 source
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Designed for specific environments, specialized speed bumps offer tailored solutions for unique traffic calming needs. The 2-foot wide models are particularly suited for dirt and gravel roads, featuring heavy-duty rubber construction with embedded yellow EPDM for high visibility1. These weather-resistant bumps are engineered to withstand harsh conditions without cracking or breaking, making them ideal for rural or unpaved areas. Each unit comes with four mounting holes (1-1/8" diameter countersink, 1/2" diameter mount hole) for secure installation, ensuring longevity and effectiveness in reducing vehicle speeds on challenging surfaces1.
1 source
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Offering a less aggressive approach to traffic calming, low profile speed humps combine effectiveness with minimal disruption to vehicles. These heavy-duty rubber constructions feature a distinctive yellow and black design for enhanced visibility, making them suitable for various settings including school zones and commercial areas1. A unique feature of these humps is the availability of male and female end caps, allowing for seamless 360° transitions when multiple units are connected1. This design flexibility enables customized layouts that can adapt to specific traffic flow patterns and safety requirements.
1 source
What are the advantages of low-profile speed humps over standard ones
Are low-profile speed humps effective for high-traffic areas
How do low-profile speed humps compare in terms of durability
Can low-profile speed humps be installed on both asphalt and concrete
What are the visibility features of low-profile speed humps
Best Car Vacuums Reviewed: Find Your Perfect Match (2024)
Car vacuums are essential tools for maintaining a clean vehicle interior, with options ranging from compact handhelds to powerful shop vacs. The Shark UltraCyclone Pet Pro+ stands out as one of the best car vacuums, offering excellent performance on various surfaces and a compact design for easy storage.
6,282
F1's Pit Stop Precision
Formula 1 pit stops are a remarkable blend of precision, innovation, and teamwork, evolving from chaotic minutes-long pauses in the 1950s to record-breaking feats like McLaren's 1.80-second stop at the 2023 Qatar GP. With advancements in pit crew coordination, single-lug wheel fasteners, and the strategic impact of the 2010 refueling ban, these high-speed operations showcase the relentless pursuit of efficiency and perfection in modern motorsport.
2,858
