Unimat Traffic's 2' Modular Speed Hump offers a versatile and effective solution for traffic calming on various road types, including dirt and gravel surfaces, designed to reduce vehicle speeds to 10-15 mph in areas such as school zones, hospitals, and retirement communities.
The 2' Modular Speed Hump is constructed from heavy-duty recycled rubber, making it highly durable and resistant to cracking, breaking, and wear from high traffic volume. It features embedded yellow EPDM rubber for enhanced visibility and can withstand extreme temperatures, constant UV exposure, and various weather conditions1. The product's versatility allows for installation on asphalt, concrete, dirt, and gravel roads, with four mounting holes (1-1/8" diameter countersink, 1/2" diameter mount hole) for secure placement1. This traffic calming solution is particularly effective in parks, guarded gate entrances/exits, construction sites, and private facilities where aggressive speed reduction is necessary1.
Featuring a dovetail design, these speed bumps offer unlimited custom connectivity, allowing for flexible installation to fit any road size and width1. The modular units lock together seamlessly, creating a uniform surface that can be easily assembled by a single person. This adaptability is particularly useful for creating single or double lane configurations, with options ranging from 18.75" individual sections to 20-foot double lane setups1. The modular nature not only facilitates easy installation but also allows for quick removal or reconfiguration as needed, making it an ideal solution for both permanent and semi-permanent traffic calming measures on dirt and gravel roads.
Installation of these speed bumps can lead to significant safety improvements by reducing traffic speeds by up to 50%, thereby decreasing the risk and severity of accidents1. This enhanced safety can make neighborhoods more desirable, potentially increasing property values. Additionally, the reduced vehicle speeds contribute to lower noise pollution levels, particularly beneficial in residential areas1. From an environmental perspective, these speed bumps are manufactured using recycled materials and can be recycled at the end of their lifespan, aligning with sustainable practices1. The product's durability and resistance to extreme weather conditions ensure long-term effectiveness, reducing the need for frequent replacements and minimizing environmental impact.
Pricing for the 2' Modular Speed Hump starts at $49.00 per section for quantities of 1-49, with bulk discounts available for orders of 50 or more pieces. Larger configurations, such as a 10 ft single lane speed bump (6 sections + 2 end caps), are priced at $354.00. Special discounts are offered for orders of 100 pieces or more, encouraging large-scale implementations.1
Customer reviews highlight satisfaction with the product's effectiveness and ease of installation. Diego Martinez praised its suitability for school areas, noting improved safety, while Ana Belen Lopez commended its sturdiness and high visibility in a hospital zone. Stephanie Thompson expressed overall satisfaction and recommended the product, indicating positive experiences across various applications.1
