  • Rubber Parking Blocks by Unimat-traffic.com
  • Speed Bumps for Gravel Roads
  • Durability and Installation Features
  • Safety and Traffic Control
  • Innovative Parking Solutions: Rubber Corner Guards by Unimat-traffic.com
Unimat Traffic Speed bumps
Unimat Traffic offers a comprehensive range of parking blocks and speed bumps designed to enhance safety and organization in various environments, from commercial parking lots to dirt roads. Their durable rubber products, including heavy-duty parking blocks with reflective stripes and modular speed bumps for diverse road types, provide effective solutions for traffic control and vehicle management.
altamira
imageextra.com.au favicon
imageextra.com
4 Advantages of Rubber Speed Humps - Image Extra
clearlinetraffic.com favicon
clearlinetraffic
The Importance of Recycled Rubber Speed Bumps AKA Bumpie ...
speed
commonwealthpaving.net favicon
commonwealthpaving
The Profound Advantages Of Rubber Speed Bumps For Traffic Safety
amazon.com
amazon.com
Unimat Traffic's rubber parking blocks offer a robust and eco-friendly solution for parking lot management. These heavy-duty blocks, measuring 72" x 6" x 4", are crafted from 100% recycled rubber, providing durability and sustainability1. The blocks feature three highly reflective yellow stripes, enhancing visibility and safety in low-light conditions.
Designed for easy installation, these parking blocks can be secured using either lag bolts or epoxy adhesive, allowing for flexible placement options. Their rubber composition makes them resistant to cracking, chipping, and fading, ensuring long-lasting performance in various weather conditions. Unimat Traffic's parking blocks are ideal for commercial parking lots, apartment complexes, and other high-traffic areas where clear parking delineation and vehicle protection are essential1.
1 source
Designed specifically for unpaved surfaces, these 2-foot wide modular speed bumps effectively slow traffic to 10-15 mph in areas like parks, school zones, and retirement communities1. The units feature embedded yellow EPDM rubber for high visibility and can be connected to fit any road width. Their heavy-duty rubber construction resists cracking and breaking, making them ideal for challenging environments such as guarded gate entrances, construction sites, and private facilities with dirt or gravel roads2. The versatile design allows for both permanent and semi-permanent installation, offering flexibility for evolving traffic management needs1.
sinoconcept.co.uk
sinoconcept.co.uk
sinoconcept.co.uk
Rubber speed bumps offer exceptional durability and ease of installation, making them a popular choice for traffic management. Made from recycled rubber, these speed bumps are highly resistant to wear and tear, capable of withstanding constant vehicle traffic without cracking or degrading like traditional asphalt or concrete alternatives12. Their flexible nature allows them to absorb shock, reducing noise and minimizing vehicle damage. Installation is straightforward, with most rubber speed bumps designed for easy bolting directly to the road surface1. This modular approach allows for quick setup by a single worker and provides the flexibility to move or reconfigure the speed bumps as needed, adapting to changing traffic patterns or site requirements12.
lubatraffic.com favicon
Strategically designed to enhance road safety, these traffic control devices effectively reduce vehicle speeds and mitigate accident risks. The bright colors and reflective elements incorporated into the products significantly improve visibility, especially in low-light conditions, alerting drivers to slow down and navigate cautiously12. By compelling drivers to reduce speed, these installations create safer environments for pedestrians, cyclists, and other road users, particularly in high-traffic areas or zones with increased pedestrian activity3. The shock-absorbing properties of rubber speed bumps not only minimize vehicle damage but also contribute to noise reduction, making them ideal for residential areas and parking lots where maintaining a peaceful environment is crucial45.
unimat-traffic.com
unimat-traffic.com
unimat-traffic.com
Unimat Traffic's rubber corner guards offer an innovative solution for protecting walls, equipment, and vehicles in parking areas and warehouses. These versatile guards are designed to safeguard 90° corners from impact damage, making them ideal for use in high-traffic zones such as parking garages, loading docks, and industrial facilities12. Made from durable recycled rubber, these corner protectors are both environmentally friendly and highly resilient, capable of absorbing shocks and preventing costly repairs to building structures and vehicles.
The corner guards feature a sleek design that complements various architectural styles while providing robust protection. Their easy installation process allows for quick deployment in areas prone to collisions, enhancing safety without requiring extensive modifications to existing structures3. By incorporating these rubber corner guards, facility managers can significantly reduce maintenance costs and improve the overall safety of their parking and storage areas.
6 sources
How do rubber corner guards improve parking lot safety
What are the benefits of using rubber corner guards over traditional metal ones
How easy is it to install rubber corner guards in existing parking lots
Are rubber corner guards effective in preventing vehicle damage
Do rubber corner guards come in different sizes and shapes
Southwest activates runway safety alerts on 700+ planes
Southwest Airlines has activated runway safety alert systems on more than 700 of its Boeing 737 aircraft as part of a fleet-wide rollout announced Monday at the Paris Air Show. The Dallas-based carrier is equipping its entire 800-plane fleet with Honeywell's SmartRunway and SmartLanding software, which provides pilots with real-time audio and visual warnings to prevent dangerous runway...
162
UK firm to mass-produce EV battery that charges in 18 seconds
The British company RML Group has received approval to mass-produce its revolutionary VarEVolt electric vehicle battery, which boasts the world's highest power density and can fully recharge in just 18 seconds, marking a significant advancement in EV technology that could dramatically reduce charging times compared to conventional batteries.
21,739
Italy and Pirelli pilot "Cyber Tyres" program that reports on road conditions
The Apulia region of Italy and Pirelli have launched a pilot project set to begin in July 2025, deploying sensor-equipped "Cyber Tyres" that will monitor and map road conditions throughout the region. According to reports from Tyre News UK, this world-first system combines data from sensors embedded in tire treads with visual information from vehicle-mounted cameras to create a comprehensive...
5,703
Infinite Machine unveils Olto modular scooter with 40 mile range
New York-based micromobility startup Infinite Machine has unveiled the Olto, a $3,495 modular electric scooter that offers 40 miles of range from its swappable 48V battery system and a top speed of 33 mph, featuring customizable components like child carriers and fold-out pedals that transform it into an e-bike, positioning it as a more affordable alternative to the company's flagship $10,000 P1...
5,898
