Skip to main content
API settings
Written by Perplexity Support
Updated over a month ago
Access our API and various models through the API settings tab. Add payment methods, monitor usage, and generate API keys to seamlessly integrate Perplexity into your workflow.
Learn more about the API here.
How can I access the API?
Simply go to Settings and click on the “</> API” tab. There, you can view and add credits, generate API keys, and monitor your usage patterns.
How do I generate and use API keys?
