Skip to main content
Data integrations
Learn more about Perplexity’s current data integrations to Crunchbase and FactSet.
Daniela Gomez avatar
Written by Daniela Gomez
Updated over 4 months ago
Data integration is a feature that allows for the combination of data sources with Perplexity's technology. This allows you to reference specific external data sources. We offer several integrations.
Crunchbase
How do I connect my Crunchbase account to Perplexity?
You can enable the Crunchbase integration for your entire Perplexity account by entering your Crunchbase API key within the Organization tab in your Settings screen.
Once activated, you can select Crunchbase as a source when you enter your search query.
If you do not have a Crunchbase API key, you can contact enterprisesupport@crunchbase.com to request and API key.
How do I search through Crunchbase on Perplexity?
Within the search box, select ‘Sources’ in the search bar and select ‘Crunchbase’. You can then submit your query and relevant sources from Crunchbase will be cited.
What Crunchbase data is provided through Perplexity?
Perplexity has select access to firmographics and Core Financials data which covers profile, funding, investment, and people details.
Can I connect my Perplexity free or Pro account to Crunchbase?
Perplexity’s Crunchbase integration is currently only for Enterprise Pro customers.
Who can turn on the Crunchbase integration?
Admins will need to enable the integration for the entire account. This will then give all other users on the account (both admins and members) access to use Crunchbase as a source.
FactSet
What FactSet data is provided through Perplexity?
Perplexity has access to FactSet Events & Transcripts and Mergers & Acquisitions data sets.
How do I connect my FactSet account to Perplexity?
  • Contact your FactSet account team for more details on enabling FactSet data for use within Perplexity for your organization, or contact perplexity@factset.com.
  • Within your Perplexity user settings, all users should enable the FactSet integration at the individual account level using the same credentials you use for logging into your FactSet workstation.
  • Once activated, you can select FactSet as a source when you enter your search query.
Who can turn on the FactSet integration?
Any User or Admin that has access to a FactSet license.
General questions
How do I search through Crunchbase and FactSet in Perplexity?
Within the search box, select ‘Sources’ in the search bar and select ‘Crunchbase’ or ‘Factset’. You can then submit your query and relevant sources from Crunchbase and Factset will be cited.
Can I connect my Perplexity free or Pro account to Crunchbase and/or FactSet?
Perplexity’s Crunchbase and Factset data integration is currently only for Enterprise Pro customers.
