What do I get with Pro?
Pro Searches
Pro users get hundreds of Pro Searches per day. You will be able to use Perplexity's Pro models and Pro Search and Reasoning features for this purpose.
Powerful AI models and Search Modes
Pro Search Models: When you need detailed answers with extensive sources, choose from Sonar, GPT-4.1, Claude 3.7, or Gemini Pro 2.5. These models deliver comprehensive responses with multiple references.
Reasoning Search Models: For complex analytical questions, select from R1 (Perplexity's fine-tuned, uncensored model hosted in the US), o4-mini, or Claude 3.7 Sonnet Thinkking. These models excel at breaking down complicated queries that require multiple search steps.
Deep Research: This mode automatically selects the optimal combination of models for in-depth research on complex topics, generating comprehensive reports without manual model selection.
Best Mode: For quick searches, this default mode intelligently selects the most appropriate model based on your query type.
If you'd like a detailed breakdown, this article introduces our four search modes (Best, Pro Search, Reasoning Search, and Deep Research) and explains which powerful language models are available for each. Learn when to use specific search modes for different types of questions and how to select the right AI model for your needs.
File and analysis
Effortlessly upload files—including PDFs, CSVs, audio, video and images—and explore their contents using cutting-edge AI models like GPT-4 Omni and Claude 3.7 Sonnet.
API credit
With Perplexity Pro, you get $5 monthly to use on Sonar. Our API gives you access to our Sonar models, allowing you to embed our AI-powered search into your own projects while having the ability to obtain citations.
Discord channel
Join the Pro Discord channel via the invite link in your Perplexity account menu. Email support if the link has expired.
Generate images
You can generate images and pick from different models. Read more here.
Pro support
As a Pro subscriber, you can access exclusive support channels:
Pro channel on Discord: Connect with our team and other Pro users.
Intercom support: Reach out directly through Intercom on your settings page. Our team prioritizes Pro inquiries and aims to respond within 1 to 2 business days.
Switching between models
You can switch between models and search modes on a single thread, this UI is located on the search bar.
Subscription management
Make sure to cancel your Pro subscription before deleting your account.
If you subscribed on a desktop, cancel through your settings page. For app subscriptions, use your device’s subscription management settings.
Why is my Pro status not visible?
If your Pro status isn't showing up:
Check for payment issues.
Make sure your billing information is correct.
Verify you're logged in with the correct email.
Clear your cache and cookies.
Try resetting the app.
If none of these steps worked, please contact support.
