For Enterprise users, Internal Knowledge Search integrates your organization’s internal files with Perplexity’s search capabilities, enhancing collaboration and productivity within your team.
Learn more about Perplexity Enterprise.
Why use Internal Knowledge Search?
Comprehensive research: Combine insights from the web with proprietary internal information for richer, more specific answers.
Enhanced collaboration: Empower your team to ask questions and get answers based on both web sources and your organization’s internal documents. Your team can make informed decisions without manually accessing or sharing files.
Increased productivity: Save time by searching across all relevant organization documents instantly.
How does Internal Knowledge Search work for Enterprise users?
Enterprise users can use Internal Knowledge Search in two main ways:
Using your organization’s file repository
Administrators upload files: Your organization’s administrators upload files to a central repository, which Perplexity can use as sources when answering questions from anyone on your team.
How to use files as sources: In Perplexity’s search bar, look for Web + Org Files. When both are selected, Perplexity will use your organization’s files and sources from the web to synthesize answers.
Deselect Web if you want Perplexity to only use your files as sources.
Deselect Org Files if you want Perplexity to only use web sources.
Deselect both if you want Perplexity to respond without external sources.
Receiving comprehensive answers: Perplexity determines which internal files are relevant and uses the most pertinent sections within those files to form its responses.
File citations: Insights derived from your internal files will include in-line citations, so you know exactly where the information is coming from. You can download and open files directly from the citation references to explore the content further.
Creating and using Perplexity projects
Creating a project: Enterprise users can create Perplexity Projects to organize their sessions and collaborate with team members. With Projects, you can create custom versions of Perplexity tailored to specific projects or topics.
Uploading files to the project: Perplexity uses files uploaded to a project as sources for search sessions within that Project, giving you customized search results based on your internal documents.
Files uploaded to an individual user’s projects are not included in the overall organization’s file repository.
Inviting collaborators: For security purposes, only users within your organization can be invited to join a project. Colleagues you invite to collaborate in a project will be able to start new sessions or continue existing ones, using the files and resources uploaded to that Project.
Personalized search experience: Projects offer additional customization options:
Upload specific internal knowledge sets: Choose which files or datasets are used as sources in your projects.
Select from advanced AI models: Choose which AI model will craft responses to your questions, including GPT-5 and Claude 4.6 Sonnet.
Set custom instructions: Provide specific guidelines or a persona for how Perplexity should construct its answers.
Learn more about Perplexity projects.
File Upload vs. Internal Knowledge Search
File upload:
You can attach up to ten files per session directly in the search bar.
Files are used temporarily within that session and are deleted after seven days.
Ideal for one-time queries with specific files as input.
Internal Knowledge Search for Enterprise:
Organization files: Enterprise administrators can upload up to 500 files to the organization’s repository, accessible to all users within your organization.
Perplexity projects: Individual Enterprise users can upload their own files to a project for use in search sessions within that Project.
Files remain accessible to all users within your organization until manually removed or updated by an administrator.
Enables comprehensive search across your organization’s entire internal knowledge base.
Learn more about File Upload.
How do I select sources for my search?
Click “Choose sources” in your search bar.
Choose from the following options:
Web: Perplexity will only use sources from the internet to generate answers
Org Files: Perplexity will only use information contained in your organization’s file repository to generate answers
Web + Org Files: Perplexity will use both web sources and your organization’s file repository to generate answers
None: Deselect both Web and Org Files if you want Perplexity to respond without using external sources.
Why don’t I see Focus in Perplexity’s search bar?
For Enterprise users, Focus has been replaced with Choose sources, allowing you to use Internal Knowledge Search by selecting between Web, Org Files, Web + Org Files, or None.
Who can access the uploaded files?
Files in projects:
Only the creator of the project and invited collaborators can access and use the files uploaded to that Project.
What file types are supported?
Perplexity supports the following file types for Internal Knowledge Search:
Excel (XLSX)
PowerPoint (PPTX)
Word (DOCX)
PDF
CSV
Note: While PNG and JPEG files are not supported for Internal Knowledge Search, you can still use these image files by attaching them directly to your query. Simply drag and drop them into Perplexity’s search bar.
For video files, we transcribe the audio to enable indexing.
Each file can be up to 50 MB in size.
How are titles and summaries generated for my files?
Titles and summaries for your uploaded files are auto-generated through a language model (LLM). While this helps provide a quick overview of your files, these titles and summaries may contain inaccuracies. If you notice any errors, please refer to the original file content for accurate information.
