Skip to main content
How to Use the Perplexity Android Assistant
The Perplexity Assistant empowers you to quickly find answers to any question, tackle tasks of any size, and accomplish more with ease
Daniela Gomez avatar
Written by Daniela Gomez
Updated over 3 months ago
With the Perplexity Assistant you can perform a wide range of voice-activated tasks on your Android device, from asking simple questions and taking simple actions, to completing complex tasks end-to-end.
It is a Perplexity layer on top of your device, integrating with many of your apps. This enables you to get assistance without the need to navigate between apps and services.
What is the Perplexity Assistant?
The Perplexity Assistant allows you to perform a wide range of tasks on your Android device, from asking simple questions and taking quick actions to tackling more complex tasks.
It is as a Perplexity-powered layer on top of your device, enabling you to quickly get assistance without needing to switch between apps and services.
How do I start using Perplexity Assistant?
To begin using the Perplexity Assistant, update your Perplexity app to the latest version and follow the onboarding steps by tapping the banner on your home screen. You can also manage the assistant at any time through your device's assistant settings.
Once it is set as your default assistant, you can activate it by:
  • Swiping from the bottom-left corner to the center of the screen
  • Pressing and holding the power button
  • Pressing and holding the home button
The activation method depends on your device. Here's a quick video showing you the onboarding steps
Gesture navigation
You can also set-up gesture navigation for the assistant for quicker access. Here's how:
What are the benefits of the Perplexity Assistant?
Our assistant brings the power of Perplexity directly to your device, allowing you to find answers to any question and take action on the needs you have throughout the day.
The Perplexity Assistant aims to save you time and make your daily tasks easier by supporting with many types of tasks - from small requests to complex actions.
