Teammates are in beta and available only to members with an Enterprise Max seat. Your organization’s administrator decides who has access. Sales-assisted organizations may have different conditions for feature access. Contact your account team for details.
Who can use teammates
To create and run a teammate, a member needs all of the following:- A seat on the Enterprise Max plan.
- Access to Computer for their organization and their role.
- Teammate access for their role.
Turn on teammates for your organization
- Open Organization settings and select Computer.
- Make sure Enable Computer is turned on.
- Next to Teammates, open the menu that shows which roles have access, such as 2 roles have access.
- Select the check box next to each role that can use teammates, or choose Select all.
Credits and billing
As with Computer, teammate work uses credits.- Who pays: The teammate’s owner, meaning the member who created it. That includes work someone else asked it to do in a shared Project or a Slack channel.
- Billing order: Credits come first from the owner’s individual monthly allocation, then from the organization pool, up to the owner’s usage limit.
- When credits run out: The teammate stops starting new work and tells its owner why.
- Parallel agents: Agents that a teammate starts for parallel tasks use the owner’s credits, and their usage rolls up into the teammate’s task.
Usage limits and reports
- Usage limits: Usage limits you set on the Usage page apply to teammate work the same way they apply to Computer.
- Who started the work: Usage reports show the teammate’s owner. They don’t show which person asked the teammate for each task.
- Usage analytics: To see teammate usage separately, go to Organization settings > Analytics > Computer. Under Credit usage, set Group by to Product.
Security and governance
Teammates run on Computer and use the same security controls:- Isolated devices: Each teammate runs on its own isolated device, with its own desktop and browser.
- Saved credentials: Credentials are encrypted. Teammates use them without seeing them.
- Connectors: A teammate uses its owner’s connected accounts and the connectors your organization allows. In a shared Project, teammates use the organization connections chosen for that Project.
- Audit logs: Teammate work appears in your audit log. See Audit logs.
- Data retention: Teammate conversations follow your organization’s retention settings for Computer.
When a member leaves
When you remove a member, or your identity provider deprovisions them:- Their teammates stop running, and their scheduled work stops.
- Their personal connected accounts in your organization are disconnected.
Teammates can’t be transferred to another member. You can transfer a Project, but the teammates in it don’t move with it.
Frequently asked questions
Is there a limit on how many people can work with one teammate?
No. There’s no limit on how many people can work with one teammate. People work with it through a shared Project or a Slack channel.How are teammates priced for Enterprise?
Teammate work is billed as Computer usage, using the same credits. The owner’s credits pay for all of a teammate’s work, including work other people ask for.Who can work with a teammate?
The teammate’s owner needs an Enterprise Max seat, access to Computer, and a role with teammate access. Other members don’t need their own Enterprise Max seat. They can work with the teammate in a Project it was added to or in a Slack channel it monitors.Can administrators set a budget for a single teammate or Project?
No. Usage limits apply to the teammate’s owner, not to a teammate or a Project. When the owner reaches the limit, the teammate stops starting new work.Who can change instructions, approve actions, stop work, or connect accounts?
Only the teammate’s owner can change its instructions, approve actions, and connect accounts. The owner can also stop its work, and in Slack anyone in the channel can stop a task.What happens when the teammate’s creator leaves?
Their teammates stop running and their scheduled work stops. Teammates can’t be transferred to another member.Related articles
- Get started with Perplexity teammates
- Computer for Enterprise
- How credits work for Enterprise organizations (admin guide)
- Enterprise roles and permissions
- Audit logs
