Who can work with a teammate
- Teammate owners: Need a Max subscription or an Enterprise Pro or Enterprise Max seat with access to teammates. On the Enterprise Pro and Enterprise Max plans, teammates are in beta, and your organization’s administrator decides who has access.
- Other people in the Project: Need edit access to the Project. In a Project your organization owns, they must also belong to the organization. They don’t need their own access to teammates.
- People outside your organization: Can join a Project if your organization’s administrator allows external invitations. In a Project your organization owns, they can read the Project chat but can’t post or tag teammates.
Where you can work together
- Project chat on the web: Each Project has a shared chat where people post and tag teammates. The chat can start with a default teammate called Project Coordinator. You can remove it from the chat.
- Slack: Tag a teammate in a channel it monitors. Everyone in the channel sees its replies. See Using Perplexity in Slack.
- Shared links: Anyone you share a teammate’s chat with can read it but can’t send messages.
Add people and teammates to a Project
- Open the Project.
- Select the Chat tab.
- Invite the people you want to work with from the Project’s sharing settings. See What are Projects? for sharing options.
- Give edit access to anyone who should be able to post.
- In the panel on the right, under Members, select Add teammate.
- Choose one of your teammates or a teammate that belongs to the Project.
- In a message, type @ and select the teammate.
- Send your request.
How to verify it worked
The teammate appears under Members. When it replies to your request, the reply appears in the Project chat for everyone who can open it.How many people can collaborate
Table 1 — Collaboration limits for Projects and teammates.
If the Project’s owner belongs to an organization or is a verified student or educator, the people limit is 9,999. Pending invitations count toward the people limit, and viewers count alongside editors. Sharing a Project with your whole organization doesn’t count toward this limit.
Who can do what
What you can do in a Project chat depends on your access to the Project.
Table 2 — What each Project role can do in a Project chat.
In a Project your organization owns, only members of the organization can post, tag teammates, or add and remove them.
Some controls stay with the teammate’s owner, the person who created it, whatever anyone’s access to the Project:
- Instructions: Only the owner can change a teammate’s instructions.
- Approvals: When a teammate asks for approval before it acts through a connected account, such as sending an email, only its owner can approve it.
- Connected accounts: Only the owner can connect accounts for a teammate.
How credits work
The person who created a teammate is its owner and pays for all the work it does, no matter who asked, in a Project chat or in Slack. Tagging a teammate that someone else created doesn’t use your credits. For other Perplexity Computer requests in Slack, see Using Perplexity in Slack for how credits work. To limit how much other people can use your teammate, add it only to the Projects and channels where you want it to work. See How credits work on Perplexity for details. On the Enterprise Pro and Enterprise Max plans, administrators can also set a usage limit for the teammate’s owner. If you’re an Enterprise administrator, see Teammates for Enterprise for organization-level controls.When the owner leaves
- The owner leaves a Project: The teammate leaves the Project too. It stops responding in that Project’s chat but is still available to its owner.
- The owner leaves the organization: Their teammates stop running, and their scheduled work stops. Their personal connected accounts in the organization are disconnected.
Teammates can’t be transferred to another person.
Related articles
- Get started with Perplexity teammates
- What are Projects?
- Using Perplexity in Slack
- How credits work on Perplexity
