Skip to main content
This guide walks Enterprise administrators through making an existing member of their organization an administrator. You assign roles from the Roles & Permissions page. The three-dot menu (⋮) on the Members screen removes a member from the organization and does not change their role.
Before you start
  • Your organization is on the Enterprise Pro or Enterprise Max plan.
  • You are an administrator, or your role includes the Assign roles to users permission.
  • You are signed in to Perplexity on the web.
  • The person has already joined your organization. Someone with a pending invitation cannot be added to a role until they accept it.
The Admin role provides full administrative control of the organization. To give someone access to specific tasks only, see Enterprise roles and permissions.
Step-by-step
  1. Go to Organization settings → Roles & Permissions.
  2. Under Base roles, select Admin.
  3. Select the Members tab.
  4. Click Add Member.
  5. In the Add members to this role dialog, enter the member’s email address in Search by email.
  6. Select the member in the results.
  7. Click Add 1 member.
To add several members at once, select each of them before you click the button. The button label shows how many members you selected. The new administrator keeps the roles they already had. Permissions are additive: the member gains the Admin role’s permissions on top of the ones they already have.
How to verify it worked
  • A confirmation reads “Added 1 member to this role.”
  • The member is listed on the Admin role’s Members tab, and the count on the tab goes up.
  • On the Members screen, the Roles column shows Admin beside the member.
  • If your organization uses audit logs, the role assignment is recorded there. See Audit Logs.
Transfer ownership to the new admin
Only the current owner can transfer ownership of an organization, and the new owner must already have the Admin role. After you add the member to the Admin role, follow the steps in Transferring organization ownership.
Remove a member from the Admin role
  4. Point to the member’s row and click the trash icon.
  5. Click Remove to confirm.
The member stays in your organization and keeps their other roles. A member who also receives the Admin role through a group keeps it until you remove them from that group.
Troubleshooting
Table 1 — Symptom, cause, and fix for assigning the Admin role.
Frequently asked questions
Can an organization have more than one admin?
Yes. You can add as many members to the Admin role as your organization needs.
Does a member lose the Member role when they become an admin?
No. Member is the default role for everyone in the organization, and the Admin role’s permissions are added to it.
Need more help?
Reach out to your account team or contact us via Help > Contact Support. Visit the Trust Center for security and compliance documentation.
Last modified on November 20, 2026
