For Enterprise users, Internal Knowledge Search integrates your organization’s internal files with Perplexity’s search capabilities, enhancing collaboration and productivity within your team.
Learn more about Perplexity Enterprise.
Why use Internal Knowledge Search?
Comprehensive research: Combine insights from the web with proprietary internal information for richer, more specific answers.
Enhanced collaboration: Empower your team to ask questions and get answers based on both web sources and your organization’s internal documents. Your team can make informed decisions without manually accessing or sharing files.
Increased productivity: Save time by searching across all relevant organization documents instantly.
How does Internal Knowledge Search work for Enterprise users?
Enterprise users can use Internal Knowledge Search in two main ways:
Using your organization’s file repository
Administrators upload files: Your organization’s administrators upload files to a central repository, which Perplexity can use as sources when answering questions from anyone on your team.
How to use files as sources: In Perplexity’s search bar, look for Web + Org Files. When both are selected, Perplexity will use your organization’s files and sources from the web to synthesize answers.
Deselect Web if you want Perplexity to only use your files as sources.
Deselect Org Files if you want Perplexity to only use web sources.
Deselect both if you want Perplexity to respond without external sources.
Receiving comprehensive answers: Perplexity determines which internal files are relevant and uses the most pertinent sections within those files to form its responses.
File citations: Insights derived from your internal files will include in-line citations, so you know exactly where the information is coming from. You can download and open files directly from the citation references to explore the content further.
Creating and using Perplexity projects
Creating a project: Enterprise users can create Perplexity Projects to organize their sessions and collaborate with team members. With Projects, you can create custom versions of Perplexity tailored to specific projects or topics.
Uploading files to the project: Files uploaded to a project will be used as sources for search sessions within that Project, giving you customized search results based on your internal documents.
Files uploaded to an individual user’s projects are not included in the overall organization’s file repository.
Inviting collaborators: For security purposes, only users within your organization can be invited to join a project. Colleagues you invite to collaborate in a project will be able to start new sessions or continue existing ones, using the files and resources uploaded to that Project.
Personalized search experience: Projects offer additional customization options:
Upload specific internal knowledge sets: Choose which files or datasets are used as sources in your projects.
Select from advanced AI models: Choose which AI model will craft responses to your questions, including GPT-5 and Claude 4.5 Sonnet.
Set custom instructions: Provide specific guidelines or a persona for how Perplexity should construct its answers.
Learn more about Perplexity projects.
File Upload vs. Internal Knowledge Search
File upload:
You can attach up to five files per session directly in the search bar.
Files are used temporarily within that session and are deleted after seven days.
Ideal for one-time queries with specific files as input.
Internal Knowledge Search for Enterprise:
Organization files: Enterprise administrators can upload up to 500 files to the organization’s repository, accessible to all users within your organization.
Perplexity projects: Individual Enterprise users can upload their own files to a project for use in search sessions within that Project.
Files remain accessible to all users within your organization until manually removed or updated by an administrator.
Enables comprehensive search across your organization’s entire internal knowledge base.
How do I select sources for my search?
Click “Choose sources” in your search bar.
Choose from the following options:
Web: Perplexity will only use sources from the internet to generate answers
Org Files: Perplexity will only use information contained in your organization’s file repository to generate answers
Web + Org Files: Perplexity will use both web sources and your organization’s file repository to generate answers
None: Deselect both Web and Org Files if you want Perplexity to respond without using external sources.
Why don’t I see Focus in Perplexity’s search bar?
For Enterprise users, Focus has been replaced with Choose sources, allowing you to use Internal Knowledge Search by selecting between Web, Org Files, Web + Org Files, or None.
Who can access the uploaded files?
Files in projects:
Only the creator of the project and invited collaborators can access and use the files uploaded to that Project.
What file types are supported?
Perplexity supports the following file types for Internal Knowledge Search:
Excel (XLSX)
PowerPoint (PPTX)
Word (DOCX)
PDF
CSV
Audio and video
Each file can be up to 40 MB in size.
Note: While PNG and JPEG files are not supported for Internal Knowledge Search, you can still use these image files by attaching them directly to your query. Simply drag and drop them into Perplexity’s search bar.
How are titles and summaries generated for my files?
A language model (LLM) auto-generates titles and summaries for your uploaded files. While this helps provide a quick overview of your files, these titles and summaries may contain inaccuracies. If you notice any errors, please refer to the original file content for accurate information.
How can I improve Perplexity’s understanding of my organization?
Your enterprise administrator can provide a brief description of your organization to help Perplexity deliver more accurate and relevant answers.
Go to settings
Click the Organization tab
In the Description field, add relevant information about your organization.
Do I need to turn anything on to use Pro Search with Internal Knowledge Search?
No. Pro Search is no longer a separate toggle, so there’s nothing to turn on. When you use Search, Perplexity applies Pro Search automatically, which helps with Internal Knowledge Search queries that need in-depth research across a broader range of sources.
Practical use cases for Enterprise users
1. Enrich internal analysis with external insights
Conduct analyses on your internal knowledge base and enrich them with external insights from the web.
Evaluate customer acquisition strategy
Initial question: “Evaluate our customer acquisition approach and provide feedback based on best practices.”
Company investment thesis
Initial question: “Provide a summary of our current investment thesis on Company Y.”
Follow-up prompt: “Have there been recent developments on Company Y that could impact or change our thesis?”
Project assessment
Prompt: “Based on everything you know about Project X, what are we missing, and what questions should we be asking ourselves?”
Follow-up prompt: “How can we address the potential gaps you’ve identified?”
Company investment due diligence
Initial prompt: “What are the opportunities and risks of investing in Start-up X, based on the provided materials and latest company news from the web?”
Follow-up prompt: “Are there any competitors of Start-up X that have recently been funded?”
User feedback analysis
“What has been the top user feedback on our new feature Y? Consider both internal feedback channels and public web sources.”
Sales battle cards
“When pitching our product Y to prospects, what common objections are likely to arise? How can we counter these objections? Provide a script.”
2. Generate content based on internal and external insights
Create better content faster by taking input from both materials your team previously created and insights from the web.
Sales lead generation
“Based on our current sales strategy and the leads we have converted so far, what new prospects would you recommend targeting that could be a good fit?”
Sales proposal outline
“Create a sales proposal for Company Y that pitches our new product X and makes a compelling case for how it benefits their business. Use insights from past sales proposals and align the pitch with Company Y’s latest strategic priorities.”
Presentation preparation
Initial prompt: “Help me prepare for our quarterly board meeting by creating an outline of the presentation based on our organization’s major accomplishments from the past quarter.”
Follow-up prompt: “Which board questions are likely to come up during the meeting?”
Marketing collateral
“Create a draft social media post, blog post, and LinkedIn update for the public launch of Product Y, based on the available product documentation.”
RFP response
“Respond to the attached request for proposal (RFP) from Customer Y, using past project deliverables. Structure the response according to the format outlined in the attached RFP.”
3. Answer specific questions
Use projects as knowledge bases and effortlessly get answers to any question.
Portfolio management question
Initial prompt: “I’m considering investing in Company X on behalf of my institutional investor client Y. Does this client have a maximum holding rule as part of their portfolio management guidelines?”
Follow-up prompt: “Any other client guidelines I should consider for this investment?”
Zoning requirements inquiry
“Review all documents I’ve uploaded related to NYC commercial zoning requirements. How far do our outdoor tables need to be from the street?”
Best practices for Internal Knowledge Search
Keep files updated: Regularly update internal files to ensure the most current information is available.
Provide feedback: Provide feedback on search results to improve file rankings and relevance.
Collaborate with your team: Encourage team members to use Internal Knowledge Search both in general Perplexity searches and within Perplexity projects for enhanced collaboration and productivity.
Need help?
For additional questions, reach out to our support team, or use Help > Contact Support to get direct chat assistance from our team and access additional resources.
