What information is synced to Perplexity?
After logging in, you must select specific folders and files to sync with Perplexity. The content and associated metadata of these files will be synced for search purposes.
Your searches will not query files or folders that you have not explicitly selected to use with Perplexity, even if you’ve successfully connected your online storage.
Do my files update when I change them?
Imported copies do not update on their own. Import the file or folder again to bring in a newer version, and remove a Project Files copy from the Project when you no longer want it. Standard Search reads the connected service at query time, so it always sees your current files and reflects access changes as soon as your source permissions change.
How is my account security maintained?
All your credentials are encrypted both at rest and in transit, following SOC 2 Type II security standards.
Where is my data stored?
Your synced files are stored in AWS S3. Custom retention policies can be applied upon request.
Will my data be used to train AI models?
No. Files from your connected Google Drive, SharePoint, or OneDrive accounts will never be used to train models.
Can I share answers based on my synced files?
Yes, you can share answers directly with other users. However, they’ll only be able to view source files in citations if they already have access to those files in the original storage service.
What file types are supported?
We currently support:
Google Docs, Slides, and Sheets
PDF, DOCX, XLSX, CSV, PPTX
MD, JSON, and TXT files
Audio: “audio/mpeg”, “audio/wav”, “audio/aiff”, “audio/ogg”, “audio/flac”, “audio/mp3”
Video: “video/mp4”, “video/mpeg”, “video/mov”, “video/avi”, “video/x-flv”, “video/mpg”, “video/webm”, “video/wmv”, “video/3gpp”
You can sync individual files, multiple files, or entire folders. When selecting a folder, all files within it will be synced. Note that syncing entire Drives isn’t currently supported.
Why can’t I select certain files?
This might happen because:
The file exceeds our 50MB size limit
The file type isn't supported
Browser extensions may be blocking the file picker (try disabling extensions or using an Incognito window)
Why can’t I connect my cloud storage service?
If you’re trying to connect to organization-managed storage, verify that your organization has granted permission for external access. Enterprise workspace users may be restricted if the service has been disabled by a workspace administrator.
How can organization admins manage connected services?
Organization admins can turn connectors on or off for the whole organization, including cloud storage connectors, in Organization settings → Connectors. See Role-based access control for connectors.
Can I control when to use my cloud storage files in queries?
Yes, you can explicitly choose when to search across your synced files from cloud storage services.
Can I sync connector files to a project?
Yes. Anyone with access to that project can search for the file, but only those with proper permissions can view the actual file contents.
Who can access my synced files?
Files synced to your personal repository are only accessible by you. Files synced to a shared project can be searched by anyone with project access, but only those with proper permissions can view the file contents.
Does installing a plugin connect my accounts or grant access to a connector?
No. Installing a plugin installs its skills. Each connector still needs to be connected by the member and is governed by Organization settings → Connectors. Installing a plugin does not grant connector access.
Should I disable the plugin or the connector?
Disable the connector. This turns the connector off everywhere, including inside every plugin.
Need more help?
Reach out to your account team or contact us via Help > Contact Support. Visit the Trust Center for security and compliance documentation.
