Skip to main content
The Connectors and Skills pages have moved into a single Plugins page. Nothing about your account has changed: your connected connectors are still connected, your installed skills are still installed, and old links still take you to the right place.
If you don’t see Plugins in the sidebar yet, keep using Customize → Connectors and Skills. Everything there works as before.
What changed
  • One page instead of two. Connectors, skills, and the new plugins are all on the Plugins page. Open it from Plugins in the sidebar.
  • Customize is now Plugins. The sidebar item that used to be called Customize is now Plugins. Memory has moved to Settings.
  • New tabs. Discover replaces the separate connector and skill catalogs. Installed replaces My Skills and your list of connected connectors. If you belong to an organization, the Organization tab replaces the organization skills tab.
  • New categories. Connectors and skills are grouped by the kind of work they support rather than by type, so a category can include plugins, connectors, and skills together.
  • One place to add your own. Add custom replaces the separate create and upload buttons for connectors and skills, and also lets you upload a plugin.
What stayed the same
  • Your connections were not disconnected and your skills were not uninstalled. They are listed on the Installed tab.
  • Connectors and skills still work on their own. You can connect a connector or install a skill without installing a plugin.
  • Each connector and skill still has its own page with the same name, description, tools, and permissions.
  • Links to the old Connectors and Skills pages, including links to a specific connector or skill, redirect to the matching page under Plugins. Update any bookmarks when convenient.
  • For Enterprise organizations, administrators manage connectors on Organization settings → Connectors and plugins and skills on Organization settings → Plugins and skills. Connector permissions apply inside plugins the same way they apply everywhere else.
Where to find things now
  • Connect or reconnect a connector: open the Installed tab, or search for the connector and open its page. The Manage connectors link in your settings and in the sources menu now opens this tab.
  • Turn a skill off or on: open the Installed tab, switch to Skills, and use the Enabled switch next to the skill.
  • Create or upload a skill: select Add custom on the Plugins page.
  • Add a custom remote connector: select Add custom on the Plugins page. See Adding Custom Remote Connectors.
  • Manage Memory: open Settings and select Memory. See Memory.
I don’t see the Plugins page
Plugins are rolling out gradually, starting with individual plans and Self-Serve Enterprise organizations, and are coming soon to sales-assisted Enterprise plans. If you still see Customize → Connectors and Skills, you don’t have Plugins yet. Everything there works as before, and your connectors and skills will carry over when Plugins becomes available.
Need more help?
Contact us via Help > Contact Support. Include the task link if your question is about a specific Computer task.
Last modified on October 14, 2026
