Before you start
- Voice mode is available to Pro and Max subscribers.
- On the web, use a desktop browser. Voice mode is not available in mobile browsers.
- For the Mac app, install or update to the latest version of the Perplexity app for Mac and sign in. See Get started with the desktop apps.
- Allow microphone access when your browser or Mac asks for it.
What you can do with voice mode
Voice mode lets you hold a natural, back-and-forth conversation with Perplexity while it works for you.
- Move around Perplexity: Ask voice mode to open a page, find and open one of your artifacts, or create and manage Projects.
- Work across sessions: Work across several Perplexity Computer sessions at once, and start new tasks without ending the conversation.
- Use your connectors and models: Pull in your connected apps and data, or ask for the model you want to use for a task.
- Start work on your Mac: In the Mac app, voice mode can also start work on your own computer.
How to start voice mode on the web
- Open perplexity.ai in a desktop browser and sign in.
- Start a new task, so the input box is empty. The voice mode button does not appear in the input box for a follow-up.
- Select the voice mode button in the input box.
- If your browser asks for microphone access, allow it.
- Speak your request.
While voice mode is on, a voice mode panel stays open as you move around Perplexity. Use the panel to mute your microphone, collapse the panel without ending the conversation, or end voice mode.
How to start voice mode in the Mac app
- Open the Perplexity app on your Mac.
- Select the voice mode button in the input box, or hold
FN.
- If your Mac asks for microphone access, allow it.
To end voice mode, select the stop button that replaces the voice mode button in the input box. To view or change the voice shortcut, see Work with Browsers and Apps.
How to verify it worked
When voice mode is on, Perplexity listens and answers you out loud. On the web, the voice mode panel is open. When you ask for an action, such as opening a Project, Perplexity carries it out while you keep talking.
Frequently asked questions
Can I use voice mode in a mobile browser?
No. On the web, voice mode is available in desktop browsers.
How do I use voice on iPhone or Android?
Use the Perplexity app for your phone. See How to use the Perplexity Voice Assistant for iOS or How to Use the Perplexity Android Assistant.
Related articles
Need more help?
Contact us via Help > Contact Support. Pro subscribers can access live chat in Settings.Last modified on November 6, 2026
